E-Class (W211) 2003-2009
Old 06-12-2015, 07:11 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Interior Guides
Print Wikipost
Loud clicking sound from panoramic sunroof
Old 05-26-2015, 07:24 AM
  #101
IncredibleShark's Avatar
w211
Same problem. can you send me repair info please?
b_astard.hs@gmail.com
but email adress withount "_"
Old 06-20-2015, 10:59 PM
  #102
Johnson964's Avatar
E 320
Smile Synchronizing the sliding sunroof (Clicking Sound)
Originally Posted by Kudyany000
Please can someone help. When i try opening sunroof the motor works but sunroof just makes clicking sound. If some one can please send instructions on how to get to a motor. My email is miberns@yahoo.com
After the battery has been disconnected or discharged you will need to resyc the sliding sunroof. (Clicking Sound)
1.) Remove the respective fuse from the main fuse box.
2.) Reinsert the fuse in the main fuse box.
3.) Switch on the ignition
4.) Move and hold the sunroof switch in the direction of the arrow until the sunroof fully close (forward) hold for 5 sec.
5.) Now open the sunroof as you would normally.
6.) The instructions are in the owner’s manual.
Old 06-30-2015, 11:15 AM
  #103
benzchk's Avatar
E320
Looking for the PDF as well to fix my pan sunroof on my E320
Originally Posted by AGPSuperstaR
Can you please send me instructions to repair my panoramic roof?
Blexmotoring@gmail.com
Thanks!
I'm looking for the PDF as well to fix my pano sun roof on E320. Motor is in good shape. Cables seem to be the issue. Any ideas on videos or pictures on how to fix it would also be helpful! Thanks
Please email instructions to aziana01@hotmail.com
Old 03-07-2016, 06:21 PM
  #104
benzR350NYC's Avatar
09 R350
Help i have a 2009 MB R350 with panoroof, the roof open and closes fine however it's the sunshade that's stuck in the closed position
Moeskrilla893@gmail.com
Old 03-21-2016, 04:21 PM
  #105
Genevieve Mcgee's Avatar
E500 Mercedes Benz 03'
Same issue cept 03
Hello I was just wondering if anyone was able to anwser your question as my husband and I are having the same issue with our e500 03'
Old 05-11-2016, 06:26 PM
  #106
Anthony Ingram's Avatar
211 e 500
I have the same problem. Two plastic arms seem disengaged. I have 2004 e 500. And it's stuck in tilt position. Could I get repair instructions. Maybe even how to remove entire sunroof
Old 05-11-2016, 06:30 PM
  #107
211 e 500
I have same problem
Originally Posted by alexdimit
Send me your email. I have the illustrated instructions for parts removal.
Please send me repair info. Anthonyingram19@yahoo.com
Old 06-07-2016, 09:16 AM
  #108
Busboy's Avatar
E240 W211 : CLK 500 W209
Also the same problem! Could you please send me the repair info. Much appreciated.
sendwesselmail@yahoo.com
Old 07-04-2016, 02:57 PM
  #109
kaaaksam's Avatar
2008 e-350 sport package
I got the same issue with Pano roof on my 2008 e-350. Can you please send me repair info as well. Thank you
kaaaksam@yahoo.com
Old 07-06-2016, 10:51 AM
  #110
Mmintzer's Avatar
07 E63 Wagon,08 R350 4matic,09 E3504matic
Having the same issue with the pano on my 2008 R350. Would you send me the repair info as well.Thank you
Lip@comcast.net
Old 01-09-2017, 12:08 PM
  #111
snowshoejeep's Avatar
E500
Exclamation Pano roof repair info
I'm another with non op pano roof needing details on how to repair.
Please send how to do this repair.
snowshoejeep@aol.com
Old 01-09-2017, 02:54 PM
  #112
jho9393's Avatar
2006 E350
I had the same issue and what worked for me is disconnecting and reconnecting the battery. I got the shade to close but I'm not gonna mess with it again.
Old 01-10-2017, 11:38 AM
  #113
E500
Exclamation
I've disconnected the battery, remove fuse 9 and re-installed same with no results....Just sounds like machine gun in all positions on the switch....
Old 01-27-2018, 10:47 PM
  #114
MPDano's Avatar
2006 R500
Originally Posted by lodilakers
I had the same problem with my 2008 E350. The Pano sun roof opened but would not close without pulling it forward while pressing the button. It sounded like gears were grinding. GEARS ARE GRINDING. DON'T TRY TO ACTIVATE THE SUN ROOF IF YOU HEAR THIS NOISE.
OK, Maybe just one more time to get it closed.
I fixed it today. Here's how I did it.
I linked a YouTube video below that shows the Overhead Control Panel removal.
Page 1 of instructions to repair sun roof motor gears.
Page 2 of instructions to repair sun roof motor gears.
Mercedes 211 overhead mirror removal - YouTube
This is a great write up, but you cannot make the image larger showing the parts you bought at Home Depot.
Leo
Old 02-20-2018, 10:37 AM
  #115
MPDano's Avatar
2006 R500
Decided to open up the console and found nothing wrong with the existing bushings. I still haven't tried the fuse in the trunk, but is is the same #9 fuse in the R500?
Thanks,
Leo
Old 04-01-2019, 02:58 PM
  #116
craigc's Avatar
2003 W211 Avantgarde (Sport), 2007 E550 Sport package
I just went through all this and fixed it with 2 washers and my HF 10 ton press.
See the gear shaft with a hex in it? when I operated the pano sunroof the shaft would move in and out with the clicking and the roof would try to close.
I decided that shaft shouldn't move in and out with a worm driven gear so I took out the 3 smaller screws off and pulled that cover off. It immediately occurred to me that the cover was bent!! see the center where the shaft is at, it had been pushed out slightly. on the inside of the cover there is a small race that rides against the larger gear holding it parallel with the worm gear. I inspected it and found no cracks so I decided I have nothing to lose and went over to my 10 ton press and put the cover on a flat piece of hardwood and ever so carefully I got it bent back to flat. The race inside that supports the gear is very close to being level with the outer edges of the case. I put a little synthetic grease in and on top of that race, screwed it back on and Boom it works great, no noise the shaft doesn't move in and out it just works. I suspect the roof had never been lubricated and that is what bent the drive cover as the motor and gearbox struggle to close the roof.
Still do the repair above as this will stop the gears from separating / clicking if the cover isn't bent already because the cover attaches to the frame around the gearbox.
Sorry I didn't take any pictures because I was in a hurry to get the roof closed before it rained.
Hope this helps someone
Old 04-01-2019, 03:06 PM
  #117
MPDano's Avatar
2006 R500
This is very helpful. I pretty much written this Pano roof ever working for us. Will give your suggestions a try.
Old 04-01-2019, 03:10 PM
  #118
craigc's Avatar
Glad I could help, post if you have any questions and I'll try to help. Also get a tube of the Mercedes sunroof grease and apply it as soon as you get your Pano roof working
Old 06-16-2020, 05:43 PM
  #119
PrettyBoss's Avatar
2015 mercedes c300 4matic
Ughh
hey I’m having this same issue with mine. One side is closing the other side is sticking up. Did you find a fix to yours?
Originally Posted by Fin2222
Any help please email to slayersnick@yahoo.com also please.
I have the problem where when the panao roof goes to close, it sticks up about an inch on the passanger side, and about 3 or 4 inches on the drivers. Can't get the thing to close and it just goes click click click, but no movement. Looks like there is a little plastic thing that is not seating right on the track. I'm going to try and take the thing off tonight in the garage. As of now I have plastic bags shoved in there so it won't rain in my car. Lucky for me there is a tropical storm in our area right now
It's an 07 E350 sport. 70,000 miles on it. First time I have had a problem. Hopefully I can take photos and show how I fixed it, or how drunk I get and start punching it.
Quick Reply: Loud clicking sound from panoramic sunroof
