E-Class (W211) 2003-2009
Old 06-12-2015, 07:11 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Interior Guides
Print Wikipost
Loud clicking sound from panoramic sunroof
Old 06-01-2010, 05:24 PM
alexdimit's Avatar
MY04 E320
Post Loud clicking sound from panoramic sunroof
New to this web site and I already got some very helpful hints. Now the panoramic sunroof will not operate and makes this very loud clicking sound that seems to be coming from underneath the light pod above the rear view mirror. Anybody have the same issue? Is it a defective motor, track, etc? Does anyone have any idea how to remove the light pod and get to the motor?
I appreciate the help and will post pics when I attempt to fix it.
Old 06-01-2010, 06:35 PM
alexdimit's Avatar
MY04 E320
Thank you, you may email them to
alex.dimitrius@gmail.com
Old 06-02-2010, 01:01 AM
ASP
ASP's Avatar
2016 Freightliner "daily driver"
Had the same issue on my 08 e350 that noise comes from the front air deflector sticking and then popping up when you open the roof. Since it rarely happened I didn't look for a fix but maybe this will help point you in the right direction.
Old 09-14-2010, 08:10 PM
gotboost's Avatar
2003 E55 AMG
Angry Loud clicking sound from panoramic sunroof
Hey I have the same problem with my roof. Just started today but it makes the sound while trying to close the sunshade which is also stuck open. Sunroof still opens and closes though. Any help would be greatly appreciated as I'm going to attempt to fix it soon. Also its not the deflector in my case, I already had to replace one of those which got stuck up and broke when I closed the roof because I didn't notice it was stuck.
Old 09-14-2010, 08:23 PM
alexdimit's Avatar
MY04 E320
On mine it was the motor for the roof part. the gear case splits (bends) and the motor gear drive is stripping out against the plastic gear inside motor. Had to remove lots of things to get to it. The overhead pod, the pillar trims, headliner ets. Got part from parts.com for $190
Old 09-14-2010, 09:16 PM
gotboost's Avatar
2003 E55 AMG
Thanks for replying so quickly alexdimit. I was hoping it might just need adjusting/tightening, sounds like it might be worse. U wouldn't happen to remember how to remove overhead pod, pillar trims etc. I don't want to break anything. Any advice or how to would be greatly appreciated. Thankx again.
Old 09-15-2010, 08:05 AM
alexdimit's Avatar
MY04 E320
Send me your email. I have the illustrated instructions for parts removal.
Old 09-15-2010, 12:39 PM
Dan Wang's Avatar
E320CDI, CLK55, and a Smart
Sounds like the motor is stripped.
Old 09-15-2010, 04:56 PM
gotboost's Avatar
2003 E55 AMG
Yes it does sound like its stripped, but the sunroof still opens and closes quietly. Its just when I try to close the sunshade that it makes that terrible noise. Are there two output gears on the motor one for the glass and the other for the sunshade. I don't know this is my first sunroof repair.
Old 09-16-2010, 05:10 AM
gaazmon's Avatar
2009 SL550 Roadster Diamond White, 2008 CLK550 Coupe Obsidian Black
same problem here and man it's been hot out here in LA
Old 10-10-2010, 05:04 PM
behzad_1647's Avatar
w211 e240
I have same problem.send for me too.tanx a lot
behzad_1647@yahoo.com
Old 06-07-2011, 07:12 AM
E55 Cannon's Avatar
2003 E55
Please send me any info/pics you have about this. I have the same issue - loud clicks when pushing sunroof button to close shades on pano. Thanks!!!
Old 06-28-2011, 07:31 PM
FreddyAMG's Avatar
E55 AMG 2005
PM your email address and I will send instruction sheets.
Hi and thanks for your help . i do have an E55 2005 panoramic and the rattling noise coming from the center piece , is there a fix that you can email me please ?
my email is ebaycomputer@hotmail.com
thx
Old 09-27-2011, 04:18 AM
rcasos's Avatar
2003 E500 and 2001 ML55
Same here. Would be very thankful if you send those to onerolo@gmail.com
Thank you very much.
Old 09-27-2011, 12:58 PM
dconner's Avatar
2006 E350
My pano is having a similar problem...neither roof or shade will open or close with switch. Makes lound popping/clicking. Is this a stripped motor? Seems like I saw a post on here about replacing the grommit and fabricating a sturdier mounting bracket. Any help appreciated. My email addy is dleeconner@hotmail.com.
Old 09-27-2011, 01:34 PM
dconner's Avatar
2006 E350
Old 10-02-2011, 08:59 PM
JFIRTH's Avatar
I'd also appreciate a copy of the information to replace the motor. Thanks, JFIRTH@AOL.COM
Old 10-12-2011, 03:07 PM
callem's Avatar
R350
Any chance of receiving the instructions on the ratcheting issue with the pano roof? I have an 2006 R-class with the ratcheting problem for the shade. my address: craigallem@verizon.net
Thanks!
Old 10-12-2011, 09:37 PM
deno's Avatar
02 E430 4matic 07 E550 4matic
Hi there can u send me it to @
Denoes@yahoo.com
Thanks in advance I have07e550
Old 10-27-2011, 08:15 AM
rwnjr's Avatar
2003 C230 coupe
Had the same problem on my '03 C230 coupe. Dealer said the frame was bent, and the whole thing needed to be replaced...for $7000. Can you send me the information as well? ralph.nichols@sbcglobal.net. Thanks.
Old 11-06-2011, 06:47 PM
wumagnate's Avatar
e500
hey do you have instructions on how to repair?
I took the front glass off the panoroof and it appears the passenger side track is off. When I crank everything all the way open with the glass off the arms that hold the the glass don't reach all the way back on the track on the passenger side.
Old 11-06-2011, 07:01 PM
wumagnate's Avatar
e500
what parts did you have to get and do you have any disassembly instructions. I've found the two arms that guide the roof are misaligned one is further back then the other.
Old 11-14-2011, 04:12 AM
niwrek's Avatar
2003 e240
guys hope you can email me the instructions too for W211, can't use my pano for months now, sometimes it has that slipping gear sound and do you guys know where I can get the ribbon wiring for the pano roof? thanks much in advance...
niwrek66@yahoo.com
Old 11-23-2011, 09:36 PM
joaa's Avatar
e55
I got the same problem for my w211, please send instructions to me. thanks.
micbeas@yahoo.com
Old 12-26-2011, 09:47 PM
Ironcross's Avatar
E55 AMG 2003, SL55 2004, 2014 E63 Renntech (Current), 2018 renntechE63 (Current)
Unhappy
I have the same problem ..thanks
aussiemattman@gmail.com
Quick Reply: Loud clicking sound from panoramic sunroof
