E-Class (W211) 2003-2009
Old 06-15-2015, 01:24 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Lighting Guides
Print Wikipost
How do I replace Headlight Bulb?
Old 01-30-2011, 02:48 PM
Schnellfahrer's Avatar
2008 MB E320 BlueTec. 2011 Porsche Boxster 987. 2016 Mazda CX-5 Sport MT, 1995 BMW K75 motorcycle
The passenger side low beam headlight H7 bulb my 2008 E320 BlueTec (identical to "regular" W211) has burned out. Does the entire headlight assembly have to come out to replace the bulb?
If it can only be reached from the back with everything in place it looks like a real knuckle chafer.
I'd appreciate any advice and suggestions.
Old 01-30-2011, 10:15 PM
SPNJHockey's Avatar
07 E350 4Matic / Sport with P1
No.
Check your owner's manual...around page 445. Has pics too.
Old 01-30-2011, 10:39 PM
Bob Evenson's Avatar
03 E320
The headlight assembly does not need to be removed, went to Auto Zone to buy new bulb and had guy with very skinny arms and long fingers change out in less than a minute. It would have taken me an hour and surely would have left some knuckle skin behind. Good luck!
Old 01-31-2011, 01:56 PM
Thank you David and Bob. Found the directions in the manual (although different page) and installed the bulb last night. The back of my hand is healing nicely from the scrapes....
Old 01-31-2011, 10:48 PM
SPNJHockey's Avatar
... The back of my hand is healing nicely from the scrapes....
LOL
Old 05-16-2014, 09:05 PM
chasewen's Avatar
09 E350 Sport
is there something special that I need to do to get the bulb out of the housing? I feel like I'm gonna break something.....
Old 05-16-2014, 09:18 PM
chasewen's Avatar
09 E350 Sport
Can't get damn bulb out
Okay, I got to to part where I pull the bulb out of the housing but, i feel like i'm gonna break something getting it out. What special jedi magic do i need to handle this task?????
Old 05-17-2014, 11:20 AM
LemonSqueezy's Avatar
14 550 sedan
Turn counter clockwise and pull?
Old 05-17-2014, 02:54 PM
chasewen's Avatar
09 E350 Sport
Stuck
Still won't come out. All i've got to do is get the stupid bulb outta the socket. I've got it out of the headlight housing already. Took off the cover, and removed the headlight plug from the housing. Just can't get the bulb outta the socket
Old 05-18-2014, 12:03 AM
chasewen's Avatar
09 E350 Sport
Got it!!! !he prongs were bent when the dealer installed it. So much for professional service
Old 05-19-2014, 03:15 AM
AMGAffalterbach's Avatar
2014 BMW M235i
They are meant to be angled to hold the bulb in. If they've never been removed before they can be hard to get out but the proper technique is the push in on the retainer clip's tabs and then do as Lemon said, simple enough.
Old 05-21-2014, 01:15 PM
beemer guy's Avatar
640i Gran Coupé
I just did the bulbs myself this past weekend. What a PITA for such a simple job! I got the bulb out OK, but then couldn't get it back in. That last 1/8 turn frustrated me. It also hurt my fingers. I waited until the next day (it's possible that alcohol consumption had "weakened" me) and wore my mechanic's gloves to help insulate the fingers. That worked! So I decided to then do the driver's side...
Oy, a worse pain, less room to work in. I removed the intake tube thingie and the coolant reservoir. The wire on that side was shorter, so it was more of a challenge to remove and replace the bulb in the socket. Then I went through the same battle getting the thing to turn when I put it back in. Yes, I got it, but I thought this was supposed to be easy?
Old 05-21-2014, 11:10 PM
2014 BMW M235i
These cars have very little room under the hood to work with, imagine having to do that several times to get your HIDs working, my arms were stinging for a few days and I'm a skinny little dude. It's easy once you do it several times, and the trick is to push in on the tabs as you twist with your fingers. But if you weigh anymore than 120 pounds good luck having room to work hahaha
Quick Reply: How do I replace Headlight Bulb?
