Go Back   MBWorld.org Forums > Mercedes-Benz Sedans > E-Class (W211)
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Members Insurance Search Today's Posts Mark Forums Read CarsGarageVendors
Welcome to MBWorld.org Forums
E-Class (W211) 2003-2009
LinkBack Thread Tools Search this Thread Rate Thread Display Modes
Old 11-05-2011, 07:05 PM   #1
Drives: 2004 E320
2004 Windshield Washer Reservoir
How do you get to this fluid reservoir? I discovered that mine leaks and never realized that until today. I was doing a pre-winter check on all my fluids and after filling it fluid started dripping on the garage floor. I see where the white translucent filler tube goes into the fender well. Is this a DIY project and what would have caused this to leak? Any ideas or solutions to my leaking solution?
tarheel76
To remove this ad, register today or login if you already are registered!
tarheel76 is offline   Reply With Quote
Old 11-05-2011, 07:40 PM   #2
konigstiger's Avatar
Drives: '71 Pinto
Quote:
Check your email.
__________________
konigstiger is offline   Reply With Quote
Old 11-05-2011, 09:17 PM   #3
Drives: 2004 E320
Thanks for the email pictures. Before I decide IF I want to take on this project what should cause this to leak? Is there bottom drain plug/seal that may be defective? Have you ever had this problem and how labor intensive is this? Thanks....
tarheel76
Old 11-06-2011, 06:18 AM   #4
Drives: 2007 E350 Sedan
I did this fix in my 2007 E350. Not sure if your configuration is the same. That being said, though, the hardest part by far was gaining access. Had to remove the right front tire and remove/peel back the wheel well covers. Once I did that, though, access was okay.
I had suspected a worn out grommet where the pump goes into the tank-apparently that is a common source of leakage. I replaced that, but my leak remained. On further investigation, I found that my pump itself was leaking, which surprised me. I replaced that, and the leak was gone. The grommet is cheap, the pump not so much so. But I got tired of seeing the puddle on the floor.
jimbo1763 is offline   Reply With Quote
Old 11-06-2011, 11:51 AM   #5
Drives: 2004 E320
Thanks for your response... The previous forum member sent me (4) detailed email pix files in the removal/replacement of the pump assembly. As per the owners manual the reservoir holds 4.8 qts. I started with a full 1.2 gallon container of RainX washer fluid and used 1.5 qts to bring it to the top of the "filler tube". Per my calculations that meant that there was 3.3 qts still in the reservoir. There has to be an "O ring" where the "filler tube" joins the reservoir and my first guess is that is the problem area. I siphoned all of the fluid from the "filler tube" (approx 1 pt.). I will keep watching my garage floor for any signs of leaking fluid. What the heck Columbus took a gamble. I live in extreme Eastern NC.
tarheel76
Old 11-06-2011, 12:02 PM   #6
If yours stops leaking after a while (once it gets lower than where the filler neck goes in), that may be right. Mine would go all the way down until the system would flash at me telling me to add washer fluid.
Old 11-06-2011, 01:37 PM   #7
Drives: 2004 E320
I have never had any signals that my fluid was low. Having owned the car for two years I doubt if I have used the washers more than 3-4 times. If the leak goes away I'll just add a qt if I get a light on the dash. Only time will tell.
tarheel76
Old 11-09-2011, 02:25 PM   #8
novae500's Avatar
Drives: W211
i have the same issue, Fill to the top and it leaks, but still have some fluid when i do use it to spray the windsheild. I dont get the low on washer fluid, So must be the filler tube oring??
__________________
05 E55: 496rwhp / 530 torque, MBH headers, Renntech 168mm, Smaller s/c pulley, EC H/E, CF Intake Tubes, TTM Scoops, HRE 547rs, OE Tuned
06 E500 4matic: wife's
novae500 is offline   Reply With Quote
Old 03-29-2012, 07:08 AM   #9
Drives: E320 & X5
W211mb
I'm having the same issue as above. I get the check fluid warning, but still has fluid. I added fluid but leaks down to where there is probably only one cup. konigstiger, would you be able to post pics on this thread? 3 years ago I paid the dealership $129 to fix this, the part listed @ only $1! even the name of the part I need to replace, bottom or (if any) top grommet would help. Thank you
__________________
'03 Black Mercedes-Benz W211 125,000+ miles
'03 Black BMW E53 3.0i 100,000+ miles - SOLD
2013 White W204
Gersh320 is offline   Reply With Quote
Old 03-29-2012, 07:11 AM   #10
Quote:
Just FWIW, my issue turned out to be a leaking pump, not a leaking grommet.
Tags
2004, class, e320, e350, fluid, grommet, leak, mercedesbenz, replace, reservoar, reservoir, sedan, tank, w211, washer, windshield
Search this Thread:
Advanced Search
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Copyright © 2001-2012 InternetBrands, Inc. / MBWorld.org. All Rights Reserved.
Everyone's Personal Details
SEO by vBSEO 3.5.2
