E-Class (W211) 2003-2009
Rattling noises from front drives side
Old 02-23-2012, 12:46 AM
Xctguy's Avatar
2003 E500 Sport, C7 CORVETTE
I have a 2003 E500, 105,000 miles, and for some time now I've been get this rattling noise from the drivers side front suspension. Its the kind of noise you hear when you go over a a little rough patch of road. Feels like a tie rod or that kinda of noise. I've taken the car to the mechanic and nothing; he even showed me there was nothing loose, or a bad shock, or any visable issues. He even heard the noise but unable to locate it. Everything was tight. I get no sounds on smooth roads...any sugguestions? HELP!
Old 02-23-2012, 03:35 AM
Freshly's Avatar
E500 "The Diplomat" W211
Could be your suspension bearings. Dealer said they rattle over bumps when they are worn out
Old 02-23-2012, 08:47 AM
06e320cdi's Avatar
2008 ML320CDI
The issue with mine were the sway bar link/bushings
Old 02-23-2012, 11:17 AM
konigstiger's Avatar
Received 4,415 Likes on 3,145 Posts
'71 Pinto
You might want to check Airmatic compressor bracket (55 in diagram) modified to resolve knocking/rumbling noise when driving over rough roads – part # 2113201843 (to comparison shop parts.com $42) & mounting hardware 2113270050 ($9).
211.056/065/070/256/265 up to VIN A735291
211.082/083/282/283/287 to X182229
211.076 to A606276
File Type: pdf
Old 02-23-2012, 02:37 PM
djrabbi's Avatar
CLS550 4Matic, C43, E350, ML350
Do you have pano? I have same thing and realize the pano creaks and cracks when going over bumps
Old 02-23-2012, 03:44 PM
Xctguy's Avatar
I dont have the pano roof. I am taking the car to the shop, I'm getting the impression its a bushing or a stabalizer link, and its only from the drivers side. Thanks for your imput!!!
Old 04-11-2012, 11:58 AM
Xctguy's Avatar
Hi Konigstiger---could you tell me a bit more about this fix. Sill after many months of this rattling, I feel you might have come up with the solution. Is this a DIY? I want to try it, any info is appreciated. Thanks!!
211.076 to A606276
Quick Reply: Rattling noises from front drives side
