E-Class (W211) 2003-2009
2006 W211 DISABLE ASB-ESP
Old 12-24-2022, 01:33 PM
HINRG65's Avatar
W211
Has anyone actually disabled there ABS-ESP fully? If so why and what happened? Were you able to re-engage? TIA
Old 12-24-2022, 05:31 PM
cetialpha5's Avatar
Received 1,467 Likes on 1,148 Posts
What are you really asking? It does become disabled if various systems go bad. The obvious stuff is a bad brake light switch, steering angle sensor, wheel speed sensor/magnetic ring, yaw sensor, etc. You need a scanner that does MB specific codes to find out why ESP might be getting disabled.
Otherwise if you actually want to know how to disable ABS-ESP on purpose, can't really help you there.
HINRG65 (12-25-2022)
Old 12-24-2022, 07:06 PM
lthlc63's Avatar
04 E55, 06 E55, 05 G55, 14 E63s, 12 cls63
only way to truly disable is unplugging your speed sensor (drove like that while tracking down a bad ground it’s a lot of fun gives the car a whole new feel)
or put in dyno mode. But I don’t recommend
Old 12-24-2022, 07:09 PM
HINRG65's Avatar
W211
I have the programming steps to disable the ABS-ESP. (My purpose is to do some testing) I'm asking if anyone has disabled the ABS-ESP and what is there experience and how easy to enable?
Old 12-24-2022, 08:39 PM
lthlc63's Avatar
its pretty damn easy to unplug a sensor and then plug it back in when youre done testing. easier than navigating through the programming.
Quick Reply: 2006 W211 DISABLE ASB-ESP
