Sign in using an external account
| E-Class (W211) 2003-2009
LinkBack | Thread Tools | Search this Thread | Rate Thread | Display Modes |
#1 | ||
Drives: E320 2003
No heat from the Vents?
#2 |
Drives: E320 2003
Really? not even 1 person?
#3 |
Drives: 04 E W211
Mine wasn't working, so i checked the collant level and i found it was down a bit. Topped it right up and now it's working fine again.
Give that a shot and see how you go. If it still doesn't work it could be the valve that needs replacing.
__________________
Mercedes-Benz Command Screen Protectors, $4.99 Posted HERE |
#4 |
Drives: 03 E500 and Corvette
When I had no heat it was the temp control valve mounted on pass side under hood at firewall. Do a search you will find al the procedures to change it,,I think it might even be in the sticky's at the beginning of the threads.
#5 |
No, it goes on only when the rear door is opened. Overengineered?
__________________
Current Ride: '07 E-550 Granite/Ash, Sports Package, P2, Wood/Leather Wheel, VCA w/ MHI Cradle & V-710 Cell Phone. Ordered 10/27/06, Built 1/27/07, Del. 2/28/07 ...a fabulous car! Gone: '04 E 500, Pewter/Stone. Had it all. |
#6 |
Drives: E320 2003
Thanks, i never notice the rear light off until now, guess it not my battery fault. Also my time to deal with the temp valve has came
DAMN YOU W211 AND ALL YOUR RANDOM PROBLEMS! |
| Tags |
| 03, 2006, 2009, 211, class, coming, e190, e500, heat, mb, mercedes, normalize, r350, rear, top, vents, w126, w211 |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Display Modes | Rate This Thread |
