Sign in using an external account
| E-Class (W211) 2003-2009
LinkBack | Thread Tools | Search this Thread | Rate Thread | Display Modes |
#1 | ||
Drives: 2004 E320 4Matic
Helicopter Noise Under Car
#2 |
Drives: [2007] Mercedes-Benz E550 4Matic
Did you check for helicopters under your vehicle before driving?
__________________
![]() ![]() ![]() 2007 Mercedes-Benz E550 | AMGAffalterbach |
#3 |
What brand of tires do you have?
#4 |
Drives: 2007 E350
Anybody missing a cat in the neighborhood?
Seriously ... the best guess I can offer is tire delamination ... tire layers coming apart from the inside out. Probably only one tire. That will give a distinct whump whump whump sound that speeds up and slows down in frequency as the car speeds up and slows. Get someone to ride in the back seat as you drive the car and produce the sound. Have the rider move from one side to the other in an attempt to identify which tire may be the culprit ... if any. Good luck. Please let us know how this gets resolved. |
#5 |
Drives: 2008 E320
are the tires cupping? Run your hand over the tread - is it smooth or is 1 edge raised?
#6 |
Update:
Tires are Toyo Proxes 225/55R16. While I was away, a family member took it back for another alignment at Town Fair Tire. They also took the car to the mechanic for an unrelated cooling system issue. Mechanic: tires "scalaped" (sic), front tires should be replaced Town Fair Tire: Camber issue, could not correct. Right front -1.1 degree camber, right rear -1.8 degree camber (both highlighted in red). Left front -1.0, left rear -1.1 (green = OK). Note is attached: "Adjustment requires the use of an adjustment bolt package, which contains 2 special bolts...allowing for CAMBER and/or CASTER adjustment. See manufacturer's documentation for further information." Has anyone had this happen? What do I need to buy/who would install it? |
| Tags |
| car, coming, cupped, driving, fast, helcopter, helicopter, inside, making, noise, sound, tire, tires, w211, whump |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Display Modes | Rate This Thread |
