Sign in using an external account
| E-Class (W211) 2003-2009
LinkBack | Thread Tools | Search this Thread | Rate Thread | Display Modes |
#1 | ||
__________________
04 Porsche 911 996 Tip/S turbo/sold 03 Porsche Boxster S/sold 03 BMW M3 SMG/sold 08 BMW 335i/sold 05 BMW 330 ZHP Package/sold 06 BMW 330ci Covertible/trade 03 Mercedes Benz CLK500 Sport AMG/sold 08 Mercedes Benz W211 E350 Sport Pkg. AMG Kits/current 12 Porsche 911/991/on the way. |
#2 |
Drives: 04 E500
Hard to diagnose the problem from here. Are you sure you got the right TPMS sensors from eBay? Early models used a 315 mHz signal, later ones are 433 Mhz. Also, the batteries in the sensors are typically good for about 4 years, and since you have an '08 model it's possible that one of the sensors you didn't replace is dying and coincidentally causing a problem that's different but has the same symptoms.
It shouldn't be necessary to have the system reset at the dealer. The dealer can speed up the process by resetting the system directly, but usually all you have to do is follow the instructions in the owner's manual, i.e., push the reset button and drive the car for a while, and it will reset itself. If trying that repeatedly doesn't work, there isn't much you can do except have the dealer check out the system. (By the way, if the dealer reset the system and it only lasted ten minutes, I'd have turned right around and gone back to the dealer immediately. That wasn't possible?) |
#3 |
Drives: 221.122 & 212.025 & 204.089
The car seems to be from Tokyo? Europe always used 433 MHz sensors, 315 MHz was for the US (NA), not sure what Japan is/were using.
The frequency is still one thing to look at but the W211 also has completely different sensors for different MY cars, from different suppliers too. It would be good to know the part number that was printed on the new sensors, a Beru sensor would not work on a MY 2008 car. |
#4 |
Thanks for the info guys, I will have to check with the parts number to see. also the frequency is should be 315mhz. I'm in the state now, not from Japan.
__________________
| Tags |
| 2006, 2012, 911, benz, frequncey, inoperational, mercedes, monitoring, porsche, pressure, reset, sensors, tire, tpms, work |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Display Modes | Rate This Thread |
