Sign in using an external account
| E-Class (W211) 2003-2009
LinkBack | Thread Tools | Search this Thread | Rate Thread | Display Modes |
#1 | ||
Drives: 2006 E55
E55 Transmission on the Fritz.. Repair shop recommendations?
#2 |
Drives: 2006 E320CDI
Find a good independent shop that specializes in MB and have them change the transmission fluid and filter. Make sure they use MB spec 236.14 fluid.
Not sure why you think the TC needs to be replaced. |
#3 |
Drives: 2004 E500 (W211)
I use Autobahn Specialists located in Tacoma. Here's a link I found to indys in the Seattle area: http://www.benzshops.com/benzshops/washington/
__________________
2004 E500 (W211) Brilliant Silver / Black Tuned by OE Tuning, Morimoto Elite 6k HID///8k LED city lights///Morimoto Elite 3Five 3k fogs with yellow laminix film///15% Johnson Silhouette charcoal tint///SprintBooster v2///aFe ProDry S filters///BT (B67875855)///AMG-style Trunk Spoiler and Roof Spoiler///Sun Blinds Kit by Nigel Marston Motorsport |
#4 |
Drives: 2006 E55
NBDT - Thanks for the website link!
I'm not really sure if the torque converter needs repair or transmission needs replace… sometimes these forums are useful, sometimes you find different people with what sounds like the same issue, but different resolutions http://mbworld.org/forums/cls-coupe-c219/137606-transmission-downshift-clunk.html ... I was actually just driving the car nicer this week and it seems to be shifting smoother.. still some slight clunking noise as the car downshifts into 2nd from 3rd or 2nd to 1st. Sometimes it happens sometimes it doesn't, so I'm thinking a fluid and filter change possibly would fix the issue. I did do the following ECU reset, but I find that if I drive nice for a while I get smoother shifting, but the minute I get on the accelerator then come back to traffic the clunking continues: --------------------------------------------------------------------------- Supposedly, the following procedure works with any "drive by wire" vehicle _without_ having to disconnect the battery: 1. Turn the ignition key to the on (not start) position. 2. Press the gas pedal to the floor and hold for five seconds. 3. Turn the key to the "off" position (don't remove the key), then release the gas pedal. 4. Wait at least two minutes for ECU to reset. ---------------------------------------------------------------------------- I’m going to opt for a fluid and filter change… using MB spec 236.14 fluid (thanks edwinwalke!) Now just wondering if indy shop would be able to check the SW or firmware? |
#5 |
Drives: MB 2003 E500 W211
E55 W211 Sluggish? - Try a search for 'Glycol'
You'll find more than you're looking for. It could be that (which is the boat i'm in). Your choices are slim and all expensive. You can get a flush/fill of atf and filter but it may not fix the issue, if its sluggish chances are your torque converter is 'gummed up' possibly from glycol which has been kown to leaked into the tranny (especially if you have that shoddy Valeo radiator).
No garage/specialist will be able to pinpoint it exactly, you just need to choose what fix path you want to go down. The cheapest being - flush and fill first; if it solves teh issue great. Next would be replacing the torque converter ($1500 + labor), if it fixes it great. 3rd would be to replace the tranny (which will come with a torque converter) and thats $8K or more. Note: if you do an ATF flush/fill and the slug goes away, that does not mean you're out of the woods. If yo have the Valeo radiator, it will gum up your tranny again in time - you must replace it. |
#6 |
valeo radiators were only on the early build cars. he has an 06
__________________
![]() W210 | W211 FOR SALE: (2) two w211 OEM heat exchangers. will take best offer! |
| Tags |
| 04, 2003, change, clutch, converter, e55, mercedes, oil, price, recommended, repair, replacement, service, shops, torque, transmission |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Display Modes | Rate This Thread |
