Sign in using an external account
| E-Class (W211) 2003-2009
LinkBack | Thread Tools | Search this Thread | Rate Thread | Display Modes |
#1 | ||
Drives: 2007 e350
Engine damage from cheap gas?? (w211)
#2 |
Drives: E550 4Matic
Spark PLugs. I think..
Also if at that mileage the plugs have not been changed, you should change them and that might mitigate your concerns altogether. Perhaps the experts can chime in and offer you more help... |
#3 |
I wouldn't worry much about someone using a lower octane fuel and causing damage. The knock sensors/ecu on the engine sense any pre-ignition and retard the timing in order to prevent damage. Unless the previous owner was racing, had a reprogrammed ecu that advanced the timing beyond reasonable specs, had a turbo or supercharger installed, or towed with regular fuel for a long period of time, there won't be any damage. I've torn apart engines that specified premium fuel and had never had premium fuel in them and there was zero evidence of damage. Many people are cheap, even with expensive autos, and will only put the cheapest fuel in all of their cars no matter what the manufacturer recommends. And the manufacturers know this, so they build engines accordingly.
The worst I've seen in my career, outside of my examples, was damaged spark plug electrodes caused by the higher combustion temps from some extended pre-ignition. Most people don't understand that octane actually retards the air/fuel mixture ignition so that higher compression engines won't pre-ignite. It doesn't add horsepower or benefit an engine that isn't designed for it, and doesn't have the electronic controls that takes advantage of it. It will actually cause hard start problems in many vehicles that are designed for regular fuel. So....in my long winded style, don't worry too much about it. If you're really concerned, inspect the plugs.
__________________
#4 |
Do an emissions test on the car before you buy it wether or not your state requires it.
My Father had a 2000 W210 that he never put 1 single tankfull of anything other than the cheapest no brand crap he could find. At 50k he needed all his cat converters replaced. We used OEM which included pipes, since I didn't want to weld new cats to old crappy pipes. That being said you are looking at a high milage not recent vehicle.
__________________
Current Ride: '07 E-550 Granite/Ash, Sports Package, P2, Wood/Leather Wheel, VCA w/ MHI Cradle & V-710 Cell Phone. Ordered 10/27/06, Built 1/27/07, Del. 2/28/07 ...a fabulous car! Gone: '04 E 500, Pewter/Stone. Had it all. |
#5 |
Low octane rating of the fuel has no bearing on catalytic converter failure. In fact, using high octane fuel in engines that aren't designed for it can cause faster catalytic converter degradation due to the fuel not burning completely and sending raw hydrocarbons into the converter which greatly raises it's operating temperature. Converter failure can be from other contaminates in cheap fuel, but not from a lack of octane. Catalytic converter chemistry is pretty simple and octane has no role in it.
__________________
#6 |
Drives: 1991 300d 2.5 turbo
hi guys, no need to worry. not that i recommend it, but we have been using 87 in our m112 engine for most of our daily driving since we bought our ML320 new 12 years ago. there is no way that a few instances of mid grade fuel will affect the engine. Do you get better fuel mileage and performance with high grade fuel, yes. Why do we use low grade if the high grade basically pays for itself... well idk. We also own a CLK55 AMG that we do use high octane fuel for, its not like we are just cheaping out.
besides, how often do normal people push their vehicle's over 3k anyways? of course WE do, but that's why i specified "normal" people haha. anytime we asked anything beyond the call of duty from our vehicle we have fed it properly with at least 91 (for towing, long car trips with the whole family + luggage, etc.) Basically all i'm saying is don't worry about the fuel, if you like the car, buy it forgot to also mention that we have about 160k miles on our ML Last edited by burrito_bandito; 06-03-2012 at 10:23 PM. Reason: forgot to add our mileage |
#7 |
Drives: 2007 e350
Wow thanks a lot for the input! (especially otto for the details), makes me feel a lot better about this vehicle, since it is cherry throuhgout.
From what I gathered, the plugs were last changed at 60k miles, but not yet at 100k... I will change them as soon as I get the car. Thanks again! |
#8 | |
Quote:
__________________
Current Ride: '07 E-550 Granite/Ash, Sports Package, P2, Wood/Leather Wheel, VCA w/ MHI Cradle & V-710 Cell Phone. Ordered 10/27/06, Built 1/27/07, Del. 2/28/07 ...a fabulous car! Gone: '04 E 500, Pewter/Stone. Had it all. Last edited by Barry45RPM; 06-04-2012 at 07:24 PM. |
#9 | |
Quote:
We see some of this in the fuel the 7-11's and such stations sell around here, but on a much smaller scale. I always recommend to my customers that they buy fuel from name brand stations that sell a LOT of fuel. The more they sell, the fresher the fuel in their tanks, as it gets refilled more often. Especially the premium tank. Some smaller stations may not get new premium fuel but once a month, or even less often. The longer fuel sits in the ground the more likely it is to get water condensing into it. Cheap fuel is not always cheap in the long run.
__________________
#10 |
Drives: volvo
__________________
| Tags |
| 2004, cheap, classs, e350, engine, gas, hard, mercedes, octane, petrol, pinging, retard, start, timing, w211 |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Display Modes | Rate This Thread |
