E-Class (W211) 2003-2009
Old 06-10-2015, 02:42 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Exterior Guides
Print Wikipost
Windshield washer Fluid not sparying
Old 12-13-2012, 11:30 AM
smokin_buddha's Avatar
2004 E500
My windshield washer's are not spraying fluid when i push the stock in to spray. The head light washers spray when i push the button.
I'm thinking it could be the washer sprayer motor. Has anyone else had a similar issue?
This time of the year i will need to repair this asap.
Thanks for your help.
Old 12-13-2012, 01:44 PM
Tschuss_Bill's Avatar
2005 E320 CDI
Do you hear any sounds? Check the fuse as well. Could be the pump.
Old 12-13-2012, 02:09 PM
2004 E500
No sound coming from the car when i push the spray stock, i was thinking the pump too, hope it wont be hard to replace!
Have to check the fuse box, wounder which fuse box the washer spray pump is in?
Old 12-13-2012, 09:52 PM
2005 E320 CDI
Have not done this repair on a w211, but I have on other german cars. Generally pretty easy.
-Bill
Old 12-14-2012, 12:21 PM
Plutoe's Avatar
Received 1,019 Likes on 947 Posts
1999 E300TD
why not locate a wiper hose junction that is between the pump and spray nozzels---disconnect and then point the end at your dog, push the on button----do fluids come out!!
Old 12-14-2012, 02:42 PM
Zishan's Avatar
E55(gone), Tesla Model S P90DL, MB GL 450
I had this issue and just had a shop fix it for $120. It took them 30 minutes. I watched them pull off the passenger front wheel as the motor or relay thingy is behind the liner.
Good luck,
- Zishan
Old 12-14-2012, 03:12 PM
2005 E320 CDI
not a bad idea. The lines pop off at each nozzle. There is a 4 bolt plastic plate that has to be removed to get to that. But if the pump makes -0- noise, I doubt that will yield any useful information.
The pump is probably snapped into an indent into the outside/bottom side of washer reservoir. Tried to find a DIY for W211, didn't see one. The pump sells for $15 to $20. I'd buy one and replace it. Worse case you're out $20 and you have a new pump.
BTW doubt there's a relay in that location. Likely fender well liner removal is likely access to the pump location.
Old 12-14-2012, 03:23 PM
Zishan's Avatar
I think you're right, I believe it was a pump they replaced.
Old 12-14-2012, 03:32 PM
2005 E320 CDI
Getting access in there is not bad. Better if the wheel was off. There are a couple 8mm nuts and at the bottom of the liner, in front of the tire, below the headlight location there are 2 of those compression pin connectors to pop out. The liner is actually 2 liners, a front have and a rear half. I think you'd only need to play with the front half. I say 'play' because you may not need to remove it entirely, just ply it away from where you need access.
That said, $120 to have the job done including parts is not bad.
Old 12-14-2012, 04:24 PM
2004 E500
Thats great information. I hope to have sometime tomorrow to look into that, im going to need it done soon, the weather in canada isnt getting any better!
for $120 its cheap, but if its not hard to remove i'd like to give it a try to DIY.
Thanks again, will let you know how it turns out.
Old 12-27-2012, 08:16 PM
2004 E500
Washer Fluid Pump DIY
Just finished the fixing the washer fluid system. Very easy to DIY... Good thing i listened to you and bought the washer fluid pump before hand!
The pump died and needed to be replaced. $50 later and max 1.5 hours (majority of time spent with the plastic wheel well front and rear cover)
The pump is located behind the rear cover.. FYI pretty much my whole tank of washer fluid dumped out when i disconnected the hose to the pump lol
Thanks again for everyone's help, I'm just hoping that all the DIY on the car will be this easy!!!! : )
Old 12-27-2012, 11:46 PM
AMGAffalterbach's Avatar
2014 BMW M235i
Hate to tell you, unless you're a mechanic probably not. However things like side-marker light swaps and things that have to do with disassembling the plastic wheel well covers are pretty easy. Did that myself and I'm really bad (or inexperienced) with these things, so I guess it really depends on the specific fix and the individual. Glad you're enjoying your new E500 and happy new year man!
Old 01-03-2013, 07:17 AM
chefswife7's Avatar
2006 C280
Angry Fluid not spraying
I think I'm having the same issue. I have an 06 C280. The wipers move fine; I hear the motor, but no fluid is dispersed. Of course we've topped off the fluid thinking it was out, but that's not it. If the motor is working, what could it be?
Old 01-03-2013, 09:15 AM
Plutoe's Avatar
1999 E300TD
Remember the motor runs a pump if the pump is shot, guess what??However to confirm all you have to do is find a connection in the hose and remove and run the pump does fluid come out?? The answer will help with a solution!!
Old 01-04-2013, 01:01 PM
2004 E500
Sounds like the pump for the washer fluid needs to be replaced, same thing that happened to me. Very easy fix, just locate your washer fluid jug, get someone to listen while you try sparying the washer fluid, if you do not hear a pump noise then thats the issue.
Good luck.....
Old 04-29-2014, 04:16 AM
vlad957's Avatar
1998 C43 Amg
Hello everyone, have the same problem on my c43 amg. When I try to spray the water on my windshield with the jets nothing happens only the wiper blade move. The pump also doesn't make a sound. I was wondering if anyone knew the part number and a good website to order one.
Old 07-26-2014, 04:32 AM
Razzle's Avatar
C180 Kompressor
Anyone know how to remove a windshield washer nozzle from a 2007 C180? Blockage is stubborn and need to remove and clean. many thanks.
Old 02-21-2018, 11:11 PM
jessejames4's Avatar
2007 Mercedes E320 BlueTec P1
Elephant in the room
I see all these posts about the washer motor not working and the fix seems to be to replace it but one question that seems to loom large in the foreground is: did Mercedes leave out a fuse or relay for the washer motor? I read this this is the case somewhere in a post and I cannot find a fuse or relay reference to the washer motor ANYWHERE. Please tell me that this is not the case... how could the motor not need a fuse/relay?
If someone has already gone through this could you please, PLEASE, let me know. I don't have an issue replacing the washer motor, would just like to cover some bases before I get to that step.
Quick Reply: Windshield washer Fluid not sparying
