Conversion- Digital Ac Control Unit
Too many german broads
Hello my 2006 e350 has the manual ac control unit, I'm looking to replace it to the e500 4 zone(03-06)unit which is digitally controlled. Ive heard this is plug and play but am confused on which I would need since after 2007 the e350's were digital but still had the manual temperature control. I have looked but have not found a correct answer, and do not know what the downside of this will be ?!
All W211 vehicles have fully automatic temperature control. Optional (or standard in some market configurations) 4 zone systems, called "THERMOTRONIC" and represented by option code 581 in all model years have both a digital temperature display and graphical fan speed indicator in a vacuum florescent display. An additional temperature control and temperature display is placed in the rear air outlet panel. Seven different versions of this control panel (and probably more software versions internally to each) exist.
Standard on most cars is a 2 zone fully automatic "THERMATIC" system. From USA MY03-06, this unit has a series of LEDs that indicate fan speed, and distribution and rotary controls for temperature selection. From USA MY07-09 the LED portion is replaced with a vacuum florescent display that graphically represents air distribution and fan speed.
Furthermore...from approximately USA MY07-09 all W211 vehicles with market variant USA no longer have a "REST" function, and instead have a MAX A/C.
Based on your description, it is not clear what system you have as you describe it as having a "manual ac control unit". If you are in the USA, and have an E350, it most likely has the two-zone THERMATIC system I have described above. As both systems are fully automatic (temperature, air distribution and fan speed) I am not sure what you are attempting to do.
Received 4,415 Likes
'71 Pinto
I have the THERMATIC 2 zone system. I am wanting to get a control unit that has the LED display found in the 03-06 e500, according to the link, this may work without an issue.
I did swap it too. It's not quite that simple Kushp14. You can't control the right side flaps for defroster and center as well as rear because your car doesn't have the necessary actuator motors.
What it gives you is a nicer looking dashboard. Unfortunately not more. I don't wanna miss it at all and I don't care that I can't control them. The car looks so much better.
What you can do is, don't go with the E500/E55 Thermotronic control unit, but with the E350 one from facelift cars. They also have the LED matrix control unit, less buttons, looks almost the same but you can control defroster and center flaps just like you can do it now.
Yes switching from 2007+ should retain all my functions with a lcd display. Does controlling the driver airflow on the left change the passenger at the same time since it is still a 2 zone ? I do not mind as long as I can keep the same functions when using the e500 unit. Also, can you still open and close the windows by pressing the recirculate button?
thanks again.
I found one from an E500 MY'05, which looks very nice, but maybe it won't work since mine is only dual zone.
I have a 4-Zone hint in my E320 with 2-Zone just bc it looks cooler with the display. It works like a charm. If you buy a later one you will lose the REST feature. That's why I said earlier buy a 2003-2004 unit to keep all the functionality. You won't gain anything except the cooler look with the 4-Zone unit. So don't expect to change a car into a space shuttle by changing the AC control unit.
If I end up with an LCD quad unit, and I can get all my current functions to work, I'm fine with that. REST is no biggie and passenger side air flow, no biggie too.
Most older units are scuffed or they come from E500 (Quad zone). You really can't find a dual unit from an '03, '04, or '05 that's an LCD. It looks like all dual zone units are just like mine. Living in CA, you really don't need the REST function, I'd rather keep engine heat out of the car, unless I'm parked somewhere where outside temp is 28F and I'm sitting in car. Maybe that will never happen to me.
W204 C63 AMG, W212 E250 CGI, C207 E250 CGI
Ey Crafty, can you please send me the link of the item youre selling? like what Mackhack says, Id like to upgrade the look but retain all the function of the buttons if I could. cheers mate!
I'm in CA too and I do like REST. If you had your AC running, you park the car, press REST and the car stays cooler for when you come back. I bought a total of 6 2004 units from used E55's and E500's which were flawless and put it in other peeps cars for them. So I really don't know why you would say one can't find good looking units anymore from these MY's. I wouldn't settle for less.
All V8 E-Class (E500, E550, E55, E63,E65) come standard with 4-Zone and therefore with the LCD unit, all non-V8s come standard with 2-Zone AC but a 4-Zone control unit will work and support all given functions.
i have a pre-facelift digital climate control
and this is what Im looking at... (courtesy of Crafty)
a couple of things im worried about,
1. my stock unit has the temp gauge on the rotating dials (L/R) the new unit has the AIR DIRECTION. would this work?
2. would all the buttons from the new unit function as it is with my car?
thanks for any clarification gentlemen. much appreciated.
when i purchased a 2 zone digital control everything worked was plug and play, vents all re-directed etc.
this is one of the threads i was trying to follow, where a few people say it's plug and play.
https://mbworld.org/forums/e-class-w...it-change.html
i can't remember what the air re-direction question brought up but i remember them saying it does work as well.. i'll see if i can dig up the old thread
Im interested with this upgrade as well. this is what I currently have in my car...
Since you won't upgrade a 2-Zone AC system with simy switching the control unit yiu need to use the driver side air vent direction dial for both sides. The passenger still won't be able to control his side (only possible in a true 4-Zone system). So don't be sad if your passenger tries to warm up her feet while you are blowing your warm are into your face. That of course is just a side note
