Last edit by: IB Advertising
See related guides and technical advice from our community experts:
- Mercedes-Benz E-Class: Why is My Key Fob Not Working?
Guide to diagnose trouble and recommended solutions
Remote Key FOB not working (E320 2003)
Hi its been a week that suddenly my remote key is not working anymore when i try to lock, unlock or open the trunk the only way i can open my doors or lock them is by going to the passenger front door and try to push the buttons when I'm next to it, otherwise its not working at all if anyone has an idea please share.
Thank you
Thank you
I would start by replacing the batteries in the fob. Instructions can be found in the owners manual. Does your other fob act the same way? If you don't have the owners manual, it can be downloaded at the link below.
http://www.mbusa.com/mercedes/servic...&class=E-Class
Mine ('03 E320) does the same, but I can only unlock/lock the vehicle from the drivers side even after replacing the batteries, I only have one FOB and waiting for the new one to arrive.
If it is anything like an E55, then check #8 fuse in the trunk (alarm/antenna fuse). 7.5A. If it keeps popping, then you have a short in the siren.
Look here: https://mbworld.org/forums/w211-amg/...s-popping.html
Sounds like there's a problem with the RF antennas in the car. If possible I'd check if the left side antenna is recognizing the unlock signal from the key.
Received 4,415 Likes
'71 Pinto
