Where A0061539928 Boost Pressure Sensor is located on the vehicle?
Mercedes Benz E 320
I need to replace Boost Pressure Sensor on Mercedes E320 Bluetec 2008. Can anyone tell me where is it located or send me diagram. Thank you.
Received 4,415 Likes
'71 Pinto
95 in diagram
Mercedes Benz E 320
Thank you for quick answer. I found that sensor earlier but part number doesn't match. Is there only one Boost Pressure Sensor? In diagnostics part number is A0061539928 and on the vehicle: A0051535028. Are these sensors the same? (They look identical in shape) thank you for help.
'71 Pinto
EPC shows 0051535028 as sender unit to air filter housing left (40 in diagram) does not note it is interchangeable, attached part list for 0061539928.
