Rear motorized sun shade inoperable-help please.
I have a 2009 E350. The rear sun shade will not go up. I can hear a slight tick sound when I hit the button. Checked all fuses - they are good. I crawled in the trunk but did not see an access point to the motor. I did not find any helpful info doing a search.
How do I get to the motor?
Received 4,415 Likes
'71 Pinto
Rear shade threads:
https://mbworld.org/forums/e-class-w...noperable.html
http://www.benzworld.org/forums/w211...ml#post4238623
Instructions to remove rear shade:
http://workshop-manuals.com/mercedes...lf/page_16499/
http://www.google.com/url?sa=t&rct=j...,d.cGU&cad=rja
2015 ML 350
I never use mine either and just had the same problem. Try to pull on it and jiggle it, then use the button. I'm sure the lubricant is all dried out and baked.
Mine works again.
Mine works again.
2009 Mercedes e350
Sunshade will not go up.
07/11/2015
I have a 2009 Mercedes E350.the sunshade would not go up . I took your advice and used lubricant on the hinges, jiggled the shade as my wife pushed the control and it worked. I do not use it much. From now on I will exercise it more often . Thank you so very much for the advice
