E-Class (W211) 2003-2009
Three Ton Floor Jack
Old 10-27-2014, 03:59 PM
Stuttgarten's Avatar
'13 E350 . M276
Sears currently has Craftsman 3 ton floor Jack, jack stands and creeper set for $99. I am thinking of buying this set, but is jack good enough for a W211 weight? How about the stands? Has anyone tried this set, or quality is a second tier type of a deal?
Old 10-27-2014, 05:40 PM
uraberg's Avatar
2006 E55 AMG
Don't know about this set, but I have a 3 ton Harborfreight low profile jack. It is just low and long enough the reach the jack point. It lifts the car just fine.
Old 10-29-2014, 01:59 AM
JDM_SXE-10's Avatar
2003 E500
A 3 ton jack is plenty. The weight equivalent of three metric tons is approximately 6613 lbs. I use a 1 or 2 ton jack most of the time and never had a problem so 3 tons should be more than enough.
Old 10-31-2014, 04:26 PM
'13 E350 . M276
Where does one place a jack stand under the W211 without causing damage to car's underside, to do oil changes for example? Would rectangle slot for factory jack work, not sure if same size, guess will have to try when I receive them. Most jack stands have a V shaped top.
Old 11-02-2014, 04:32 PM
AMGAffalterbach's Avatar
2014 BMW M235i
You can use a floor jack with the factory jack points, it won't damage anything.
Quick Reply: Three Ton Floor Jack
