E-Class (W211) 2003-2009
Just got a letter from MBUSA re: Tanks
Old 01-20-2015, 04:09 PM
2.7Tallroader's Avatar
W211
I just got the letter from MBUSA, they are extending the warranty for fuel tank and components for E-Class and CLS-Class vehicles to 15 years unlimited mileage.
W211. (01-16-2020)
Old 01-20-2015, 06:53 PM
CaptMike's Avatar
2003 E320
Yes, I just received the same letter.
The letter states:
"It is important that any repairs made under this warranty extension are preformed by an authorized Mercedes-Benz dealership."
This is my situation:
I replaced both fuel pumps about 11 months ago...obviously not within the factory warranty period and not by Mercedes-Benz.
Is this a catch 22?
IF this new Warranty Extension for the fuel tank components would have been in place before my needed repairs, of course I would have them done at a MB dealer. However my repairs were nesseary before this extension was put in place by my non MB mechanic.
Am I screwed on reimbursement of my costs from MB?
Sounds like a class action law suite may be appropriate.
Old 01-20-2015, 10:07 PM
RCPDesigns's Avatar
2007 e350, 2013 C250, 2004 C320, 2003 C320, 1998 CLK 320
Got the same letter today. I think we will be taking the 2004 E320 wagon in and see what they will do. For the last couple of years we've stopped filling the tank at about the 3/4 mark... anything more and you can smell gas. I guess this will fall under the warranty extension.
I had my 2007 E350 fixed last year when it developed the same problem... but it was still under the extended warranty. It has been fine since.
Old 01-20-2015, 10:35 PM
bernard farquar's Avatar
2011 E350, 1998 ML320
I just got the same letter. I think I will take the back seat out and see if I have any evidence of leakage.
Old 01-22-2015, 07:02 PM
meooem1's Avatar
2004 e320 and 99 e320 wagon
Just got my car back from the dealer and they put a new tank in free of charge. . I should have pushed for new rear seat foam because it reaks of gas.
Old 01-22-2015, 08:04 PM
slimsol's Avatar
1999 slk
Did they give u loaner car? was it free loaner?
Old 01-23-2015, 11:05 AM
CaptMike's Avatar
2003 E320
I took the fuel tank components warranty extension letter to the service manager at my local MB dealer. This was the first time he stated he saw this letter. He stated that after I put together all of the required elements stated on the back of that letter (my repairs were not completed by MB, but by an outside shop), to bring it all back to him personally. The letter does state: "Reimbursement will be made by check from your dealer." and "The following documentation must be presented to your dealer for reimbursement." So my question is:
What is the enclosed postage paid envelope for that was included in that letter?
So I'm suppose to "trust" the service manager to follow through with this once I hand him the required documents?
Yes, I did make copies of everything
Old 01-23-2015, 11:28 AM
RCPDesigns's Avatar
I understand one use of the envelope is to update the status of ownership of the car (sold, destroyed etc) so MB knows where the car is and that they've made every reasonable attempt to contact all owners.
Old 01-23-2015, 11:34 AM
CaptMike's Avatar
2003 E320
LOL....yes I see that now. I should have read further up the back of that letter.
Thank you
Old 01-23-2015, 11:51 AM
tonyrobot22's Avatar
2007 Mercedes E350
I just brought my 07' E350 to the dealership to have them replace the O Ring I paid for this past summer, and had them replace it because of the Gas Fume smell inside the cabin. I paid $300. I figured it was a faulty O Ring and have always questioned the fact that there should've been a recall. Guess what everybody? As of January 2015, Mercedes finally recalled all W211 gas tanks because of cracking and leaking gasoline!!! They are installing a new tank today at NO CHARGE!!! And they are refunding me the $300 I paid for the O Ring! If you have a W211 and have had the same Gasoline smell inside your car, call your local dealership or service center and let them know that this is finally recalled and can hopefully be fixed! If you already paid for a new tank before January 2015, then there should be a full refund from Mercedes! I should be getting my car back today and will let you all know if the new tank fixes the problem. Good luck to everybody!
Old 01-26-2015, 05:47 PM
balthus's Avatar
2017 E400 Wagon Black/Black MB Tex P1 & Sport Wheel Package
We have a 2004 E320 wagon and have had this issue but did not receive a letter although we have moved from address that may be on file with MBUSA from when we originally bought the car. How do we get a copy of the letter or find out about any recalls on our vehicle? Thanks.
Old 01-26-2015, 05:56 PM
konigstiger's Avatar
Received 4,411 Likes on 3,144 Posts
'71 Pinto
To monitor ongoing "recalls" http://www.mbusa.com/mercedes/recall, this is a "warranty extension" letter found here: https://mbworld.org/forums/e-class-w...ml#post6297916
Old 01-26-2015, 06:05 PM
balthus's Avatar
Thank you so much. We have been smelling gas terribly if we fill the tank all the way. Nothing came up under our VIN # as active recall but will contact our SA our dealership.
Old 01-26-2015, 06:10 PM
CaptMike's Avatar
2003 E320
UPDATE:
Took the required paperwork that was stated on the extension letter to the service manager at MB today.
The grip that was stated on my fuel pump replacement from my non MB mechanic stated:
"Work Requested-Cust Request to inspect Vehicle Crank Over Won't Start & Fuel Smell Inside CK and Advise"
"Work Preformed-Short Test Preform, Inspect For No Start, Found No Codes Present. Test Fuel Pressure, No Pressure, Tested Electrical Found Power & Ground @ Pump Also found Leakage At Pump Assembly. Found Left Side Sending Unit Leaks, Found Right Side Pump Burnt Out, Replace Faulty Fuel Pump Sender Assembly & Faulty Fuel Pump Assembly W/Sender Unit & Fuel Sender Seal & Fuel Pump Mounting Brat & Fuel Pump Mounting Brat & Update Fuel Pump Wiring Harness"
MB Manager stated: "Good thing that fuel smell was mentioned because the last customer did not mention the fuel smell and MB declined the claim"
Old 01-26-2015, 07:56 PM
balthus's Avatar
Oddly enough I just got home from work and the letter had come in today's mail so I guess they have our current address but thanks again.
Old 01-28-2015, 01:12 PM
ParadiseLV's Avatar
2008 E550
Do we have to apply for a claim to get a letter?
Old 01-28-2015, 01:25 PM
'71 Pinto
Follow second link in post 12, print letter.
Old 01-28-2015, 02:33 PM
slimsol's Avatar
1999 slk
I havent gotten any letter but i have appointment tomorrow for fuel tank replacement. I will update you guys tomorrow
Old 01-28-2015, 09:22 PM
Hsg08's Avatar
MB W212, MB W218, BMW F06, BMW F48
I havent received any letter yet for my E350 and my E55. I know for fact that they havent started fixing any w211 AMGs yet. Did you call your nearest dealer and give them your vin #? What did you do though? Thanks
Old 01-29-2015, 05:23 PM
slimsol's Avatar
1999 slk
SA from dealership just called to inform that he ordered parts from east coast and it will take few days to install fuel tank. They gave me free loaner. a 2015 c300
Old 01-31-2015, 07:01 PM
snm767's Avatar
2003 E320
Mercedes has settled with NHTSA on the fuel system issue. They are extending fuel system warranty on all 2003-2009 E Class for 15 years AND NO MILEAGE LIMITATIONS. Got my tank replaced along with sending unit and pump this past Thursday (1/29/2015) FREE OF CHARGE AND RENTAL CAR INCLUDED. Call your dealer with your VIN number and make an appointment! Life is good !
Old 01-31-2015, 07:02 PM
snm767's Avatar
2003 E320
snm767's Avatar
2003 E320
No, just call you dealer with the VIN.
Old 01-31-2015, 09:19 PM
benznewcomer's Avatar
porsche
i have a usa e55 but im in canada....can I still get this replaced?
Old 02-01-2015, 08:42 AM
snm767's Avatar
2003 E320
Yes. Free loaner was provided.
Quick Reply: Just got a letter from MBUSA re: Tanks
