Parktronic not working E 240 W211
Hi all,
Would like to know if there is a way to get the Parktronic to work on my 2005 e240. No lights are flashing when in reverse no sounds. The off switch near the gearshift does not light up when pressed. Seems like it may have been deactivated.
I have checked to fuse in the trunk and it seems ok.
Any advice would be much appreciated!
Received 4,415 Likes
'71 Pinto
Long shot but check the wiring bellow shift, removal shown here https://mbworld.org/forums/e-class-w...re-broken.html
W211 Parktronic
Fuses can be tricky to locate in the trunk of the vehicle, but the last 3 at the bottom of the vertical row of fuses should be checked and replaced, may need a wiggle. Worked a treat for me, parktronic is a treat!
