W211 E200 Cdi battery problem
W211 E200 CDI 90kw
Hello!
I got really big problem with Red battery message ( Visit workshop)
I scan Battery Control Module with my diagnostic tool i get fault code "9055 - The terminal 61 signal on the CAN bus is missing or is faulty."
but that fault code say nothing for my problem.
Problem 1
I also check voltage output from my alternator to main battery guess what? i got 12.3v seems fault is here but its not i change alternator to the new one, and still get the same voltage output from alternator, but something interesting is that, when i accelerate output goes from 12.3 to 13,9v and 14v and doesn't goes down, seems okay? i think it should go to the 13.5v when i start engine without accelerate? then i check "Drive Belt Tensioner" i change it also because it was in bad condition, but still same problem with charging a battery from alternator, doesn't charge if i don't accelerate on high revs.
I also change both batteries "AUX battery and Main battery" still got the same problem Red Battery Message on my dash, then i change Aux Battery Relay and clear the codes with my diagnostic tool, start the engine and again same pop up with "Red Battery Message" i took my voltage meter and checked Aux battery with engine on, got 12.2v seems its not charging, i being to look all fuses, all fuses was in good condition expect one in "F32 fuse box" i change it and i got the same fault code on my dash.
Then i change Battery control Unit but problem was not gone.
I spend a lot money to trying fix that "Red battery Message" on my screen.
Maybe you guys will help me to find out my car's problem.
Sorry for bad English.
Problem 1
Received 4,414 Likes
'71 Pinto
Assuming vehicle is MY03-06 could be the relay (current part # 0025424719), faulty relay will give you red warning. If f70 was bad (front prefuse, interior foot well) this is for battery relay http://workshop-manuals.com/mercedes...ion/page_4935/ to replace see here (wheelhouse) http://www.google.com/url?sa=t&rct=j...,d.eXY&cad=rja
W211 E200 CDI 90kw
Hey! Thanks for your reply!
but i have tried 3 Aux battery relays, i bought one new aux battery relay from local car parts shop, the second one is old from my car the OEM part, third one i had try to put from my friends w211 also OEM part. Still same Red Battery Message
'71 Pinto
Have someone clear/pull codes with MB DAS. If alternator is rebuilt (usually a weak point in this scenario) revisit other than this not much more I can offer.
check battery control module in trunk ( usually near trunk latch). Sometimes electrical connections are not plugged all the way in to the module. causes warning light to go on. Worth a try.
Received 1,466 Likes
I think it's the mobile site. Tends to show old threads after a new one so if you keep scrolling and don't pay attention, all of a sudden you're replying to an old thread without realizing how old it is.
