A/C Blower Motor Bracket Needed
A couple of days ago, I took off my A/C Blower Motor to lubricate the bearings using 3-in-one Blue.
I ended up breaking one of the 4 tabs of the plastic housing that screw the unit to the car, now it's attached with 3 torx screws only. It's working fine, but just the thought that I having a missing screw is unsettling.
So, if you've replaced your unit, and you have the black plastic/ABS housing with intact tabs, and you have no use for it, please let me know. I'm willing to pay for shipping. Just send a PM.
Super Moderator
JBweld will fix that right up! And if you want it to be even stronger you could jbweld a piece of metal or wood over the joint and drill a hole through it to countersink the screw into.
Honestly I bet 3 will be fine though but it would be bothering me a ton too.
Here is my last JBweld use
http://postimg.org/image/4tr52i6j1/
saved me $250
saved me $250
