E-Class (W211) 2003-2009
Secondary air injection system malfunction
Old 06-29-2015, 08:30 PM
07BlackWidow's Avatar
2007 E350
So I've been driving with the check engine light on for about 2 months now. The code is for secondary air injection pump, I keep pulling the code to see if there is others hiding behind this one. Today I did it and now there's a code for secondary air injection system malfunction. Has me not fixing the secondary air injection pump caused more problems? Any help would be great!
Old 06-29-2015, 09:53 PM
cmriv's Avatar
2009 E550 2000 Honda civic mash n' go
what did you "fix" already?
Old 06-29-2015, 09:56 PM
cmriv's Avatar
And if you replaced anything previously make sure those vacuum lines coming from the pump to the manifold are routed correcty
Old 06-29-2015, 09:57 PM
2007 E350
Well I changed my air filters and forgot to plug the hose from the pump back into the air box so I thought that was the problem. I plugged it back in and cleared the code and it came back. Fuse was good, so I have changed the relay and that's it.
Old 06-30-2015, 08:07 AM
cmriv's Avatar
I would assume your pump may be faulty. But the only way to really decipher what is going on is star. That should be your next step!
Old 06-30-2015, 07:28 PM
2007 E350
Alright thanks for the help. Will it hurt anything if I still drive it unfixed?
Old 07-01-2015, 02:14 PM
Plutoe's Avatar
Received 1,019 Likes on 947 Posts
1999 E300TD
No!!
Quick Reply: Secondary air injection system malfunction
