E-Class (W211) 2003-2009
Re-use new valve cover gasket?
Old 08-02-2015, 08:55 PM
naterator's Avatar
2004 E320W
Hi guys, did the valve cover gasket on the wife's E320 wagon this weekend. Billowing smoke at startup told me something wasn't right. Checked the bolts and sure enough, the right rear bolt is broken.
But my question is, do I need to get a new gasket again, since the car ran for 5 minutes? Or can I just get that bolt out, wipe off the gasket and put it all back together?
Thanks much!!!
Old 08-03-2015, 07:33 AM
boardboy330's Avatar
2000 ML320, 2005 E320 CDI
I would buy a new gasket myself - but if you chose to reuse there shouldn't be a huge concern.
Old 08-11-2015, 06:01 PM
Former Vendor of MBWorld
CarPartsDiscount.com's Avatar
1985 500SEC
If there was no sealant used then chances are you are good to go. If you used some sort of sealant you will need to replace the gasket.
Quick Reply: Re-use new valve cover gasket?
