E-Class (W211) 2003-2009
After market Android 4.4.4 Quad Core complete install. Vids and Pics and txt
Rating: Thread Rating: 2 votes, 5.00 average.
Old 11-27-2015, 01:23 AM
  #101
tubaprde's Avatar
E55, past: SL55, 560SEL
Originally Posted by yusabdu
How to make the cd changer works, just to open the tray so i can use it to store CDs
I don't have an answer for this. When I installed the new head unit the 6 disc changer in the dash stopped working (it no longer pops out). There must be some solution out there?
Old 11-27-2015, 01:24 AM
  #102
tubaprde's Avatar
Originally Posted by NCBenzUser
Hi, I am seriously considering this upgrade. Can someone share how wires are routed between the trunk and the unit? Are there tracks to run the wires and are they easy to get to ( covers easily removed ) ? btw, my vehicle does have the HK speaker system and navigation which no longer works.
I'm pretty sure Expression explains this and his first post?
Old 11-27-2015, 07:08 AM
  #103
KarmaIT's Avatar
2006 W211 E500 Facelift
I am trying to work out how to power the changer to open, when i find it I will let you know
Old 11-27-2015, 09:22 AM
  #104
tubaprde's Avatar
Awesome thanks. And if I find a solution to the Bluetooth echo on the other end I will let you know. (A solution that does not involve soldering and rewiring the unit)
Old 12-04-2015, 04:40 AM
  #105
Gangrene3075's Avatar
03' Mercedes-Benz E500
I chose Option #1
Old 12-04-2015, 05:19 AM
  #106
KarmaIT's Avatar
im getting through mine, taking a long time, its been warm here last little while and work keeps interrupting haha
still have to build a proper surround for amps, mono is in the spare wheel well
i love how this looks haha
early stages, testing the rig out before actually mounting and tidying everything
crossovers hidden
Old 12-04-2015, 07:38 PM
  #107
tubaprde's Avatar
im getting through mine, taking a long time, its been warm here last little while and work keeps interrupting haha still have to build a proper surround for amps, mono is in the spare wheel well i love how this looks haha early stages, testing the rig out before actually mounting and tidying everything crossovers hidden
Wow very nice work! Are you getting a lot of trunk rattle or did you somehow reinforce that so there isn't vibration noise?
Also how is your Bluetooth quality for the person on the other end echo wise?
Old 12-05-2015, 04:04 PM
  #108
mikeschuster's Avatar
CLS550
Very glad I found this thread as my COMAND unit in my 2009 CLS550 just broke (it goes into a reset loop and doesn't boot anymore). MB wants >$5000 to replace it which is insane. I am now looking for a proper replacement and this unit seems to be the best option. As the 2009 CLS550 is the W219 (C219) this unit should fit but neither of the two sources from above list the 2009 CLS550 as a car this would fit in:
http://www.aliexpress.com/item/Andro...2ef9eaa42c8ec3
http://www.ebay.com/itm/201423007488?rmvSB=true
Is this just an oversight or is there a specific reason why this unit would not fit a 2009 CLS550? Any info appreciated...
Thanks,
Mike
Old 12-05-2015, 04:10 PM
  #109
NubyIz's Avatar
C219 CLS350
Hi,
Do you know which version NTG you got?
NTG2?
Could take a pic possible?
Also which AMP have you got?
Might have to look behind left panel in boot.
Should be NTG2 from recollection think they switched to that from 2007 to 2010.
Cheers
Old 12-05-2015, 05:30 PM
  #110
CLS550
Originally Posted by NubyIz
Hi,
NTG2?
Cheers
I am pretty sure I have NTG 2.5 (with 6CD changer, not sure about the audio, I think it's Bose). I will take a pic once the car is back from the dealer.
Old 12-05-2015, 05:35 PM
  #111
NubyIz's Avatar
C219 CLS350
Hi,
Correction: NTG1 and NTG2.5 should be compatible to a degree, but you may need a different harness.
Cheers
Old 01-02-2016, 04:25 PM
  #112
JoeNobody's Avatar
Mercedes
Ntg2.5 would work, but you will need to rewrite some of the included harnesses.
Does anyone have fitment issue with the head unit? I cannot get mine to fit flush, as it sits out a little and I cannot figure out what's going wrong. The wires in the back are not getting in the way either.
Old 01-02-2016, 05:14 PM
  #113
NubyIz's Avatar
C219 CLS350
Got the same issue, stands out by maybe 3-5 mm.
Will take out again shortly and compare with my original NTG1.
Or maybe some wire sticking out at the back will see.
Cheers
Old 01-02-2016, 11:15 PM
  #114
JoeNobody's Avatar
Mercedes
I figured it out. You have to cut/grind down a hump of plastic on the dash that's between the mounting holes. It's an square section about an inch, with ridges. Now it fits perfectly flush.
iPhone with lightning cable does not work with the stereo, but I will try using a 30-pin adapter and cable and then it'll probably work.
Is a way to adjust the button backlighting color? I see a backlighting color setting in the factory settings but it doesn't appear to work.
I still need to change the dashboard coding and remove the nonfunctional phone and navigation menus.
Old 01-02-2016, 11:29 PM
  #115
NubyIz's Avatar
C219 CLS350
Hi,
Great to hear. Did you happen to take a snapshot to share?
Cheers
Old 01-03-2016, 12:52 AM
  #116
JoeNobody's Avatar
Mercedes
I will take a photo when I open the dash up next week
Old 01-03-2016, 08:19 PM
  #117
JoeNobody's Avatar
Mercedes
There's a different rom that has better support for steering wheel controls?
Does anyone have more info?
I have a 5 channel class D amp installed with the new head unit and it sounds fantastic.
Old 01-03-2016, 09:33 PM
  #118
das eighty's Avatar
'04 E55 AMG
JoeNobody,
I believe you are talking about the Malaysk ROM. There is a looooong thread on XDA with multiple mentions of it. They have branched out some of the forum because of the multitude of brands/manufactures of these units. From what I've been reading, Malaysk has stripped the ROM of a lot of bloatware and has a pretty solid thing going.
Here is the thread. Hopefully that helps.
Old 01-04-2016, 05:01 PM
  #119
JoeNobody's Avatar
Mercedes
Has anyone tried installing a front camera? The head unit has a second composite video input, but it looks like some are using USB cameras for the front camera? It would be amazing to get one of the driving lane assist apps to work correctly.
Old 01-05-2016, 06:03 PM
  #120
tubaprde's Avatar
I never got my dvr can to work. I'm not sure if it's a faulty head unit for faulty camera?
Old 01-07-2016, 12:51 AM
  #121
JoeNobody's Avatar
Mercedes
I just upgraded to Malaysk and it's so much slicker than the stock rom. Very easy to upgrade too.
Old 01-07-2016, 09:29 PM
  #122
das eighty's Avatar
'04 E55 AMG
Glad to hear that! Care to share a video or two? How will you go about obtaining a data signal? Tethering to your phone or USB device?
Old 01-07-2016, 10:42 PM
  #123
JoeNobody's Avatar
Mercedes
The instructions are in the first post of that enormous XDA thread, but basically you just download a 500mb file, copy it to the maps SD card, pop in the card and then on the unit go to Settings -> About -> System Updates, and it'll prompt you to install the rom.
For data I'm using iPhone wifi hotspot sharing. Google maps apps now allows you to download offline maps, so you can use that without bothering with data tethering.
Old 01-08-2016, 07:17 PM
  #124
tubaprde's Avatar
The instructions are in the first post of that enormous XDA thread, but basically you just download a 500mb file, copy it to the maps SD card, pop in the card and then on the unit go to Settings -> About -> System Updates, and it'll prompt you to install the rom. For data I'm using iPhone wifi hotspot sharing. Google maps apps now allows you to download offline maps, so you can use that without bothering with data tethering.
What has been your impression of talking on the phone via Bluetooth? For Whatever reason the audio for the person talking on the other line is horrible. I wonder if updating to this rom would fix that?
Old 01-08-2016, 07:36 PM
  #125
NubyIz's Avatar
C219 CLS350
For it seems ok. But I noticed when talking to another guy with exact same stereo that I got a strong echo of my own voice.
Suggest to turn down volume.
Also consider using an external microphone
Also keep in mind these unit seem to have an issue with the mic hardware and amp.
For a proper fix u would likely need a hardware mod.
http://forum.xda-developers.com/showthread.php?t=266066
Look for "Mic sound is awful and click show content.
Cheers
You have already rated this thread Rating: Thread Rating: 2 votes, 5.00 average.
Quick Reply: After market Android 4.4.4 Quad Core complete install. Vids and Pics and txt
