E-Class (W211) 2003-2009
replace knock sensors?
Old 08-29-2015, 01:23 AM
bewbzout's Avatar
06 E55
I am in the process of replacing the intake manifold and I am wondering if I should replace the knock sensors while I'm at it. Are they a common thing to go bad? Anything I should do while I have the intake off? There was some oil in the valley, what causes this? Thank you for the help. -Josh
Old 08-29-2015, 10:05 AM
bewbzout's Avatar
06 E55
Forgot to mention car has 82k
Old 08-31-2015, 03:41 AM
AMGAffalterbach's Avatar
2014 BMW M235i
What car do you have first off? And I haven't really heard of the knock sensors going bad on the M272/M273. Don't think they do either on the M113k if it's an E55 that you have. Have you done air filters while the intake is off? Lol
Old 09-01-2015, 06:20 PM
LemonSqueezy's Avatar
14 550 sedan
Knock sensors should rarely ever go bad. No need to replace it. I've had a knock sensor code pop up once in conjunction with a bad ignition coil, replaced coil and knock sensor code never came back.
Old 09-01-2015, 08:40 PM
2014 BMW M235i
^Same, knock sensor codes have all been related to failing coils for me. $59 at Advanced and 15 minutes of work later it will be resolved.
So, if you have some extra cash, and you have a high mileage car, I would consider doing ignition coils actually
Old 09-03-2015, 10:11 PM
bewbzout's Avatar
06 E55
Thank you guys for the replies, I ended up not replacing them.
Quick Reply: replace knock sensors?
