Turn signals will not self cancel
2005 E320 CDI & 2011 E350 BlueTEC
Hello,
Car: 2005 M-B E320 CDI
Problem: Turn signals won't self cancel
I had reason to pull my steering wheel and the various plug-in components (wiper controls, power column adjust, turn signal switch, cruise, etc.) and when I got everything buttoned back up, my turn signals will not self cancel any more.
They blink fine, the lane change feature works properly, howcver, the self-canceling feature that normally clicks off the blinker after making a turn no longer works. It did prior to disassembly. Neither on LH or RH turns.
Does anyone know what I need to do?
Thanks!
-- ER
Thanks!
-- ER
turn signals
Yes, it is intact. There were no cuts, tears, etc.
I cannot be certain the number of "rolls" it had or now has.
Ideas? Suggestions?
Thanks from Eddie
Ideas? Suggestions?
Thanks from Eddie
Received 4,415 Likes
'71 Pinto
Possibility...
turn signals
Thank you for that chart and printed information. I will address the problem using that information.
I am most appreciative and will update later on.
-- ER
-- ER
Here is a video about how to rotate it...
http://forums.mercedesclub.org.uk/sh...=139873&page=3
But shouldn't it trigger your ESP fault is installed wrong?
I remember reading that there are some spring loaded 'positioners' in multifunction switch too, which may have failed?
