E-Class (W211) 2003-2009
E500 upgrades and tuning.
Old 11-06-2015, 03:40 PM
shondyracing's Avatar
2003 E500 swap
First of all don't say "buy a E55". I'm half way though my 2003 e500 build. I'm just here to swap ideas. Questions etc.
Old 11-06-2015, 09:30 PM
marc hanna's Avatar
2008 R320 CDI, 1987 560SL
Kleeman supercharger and LSD
Euro version larger throttle body
SLR Cams
-then you'll have 750+ Hp
Is that wrapped or painted?
Old 11-07-2015, 02:14 AM
2003 E500 swap
It's dipped.
Old 11-07-2015, 08:49 AM
marc hanna's Avatar
Even better
Old 11-09-2015, 02:15 AM
2003 E500 swap
Ok, so got my c4 stars system in. Seems there is a torque limited? Whither the work I have done it should be around 400hp and 430tq. I need to remove the speed limiter also. Another thing is quicker up and down shifts. Any ideas before I go manual?
Old 11-09-2015, 07:50 AM
cmriv's Avatar
2009 E550 2000 Honda civic mash n' go
WHOAAA.... That wing though....
Old 11-09-2015, 08:49 PM
AMGAffalterbach's Avatar
2014 BMW M235i
What work have you done to an E500 to make it 400hp and 430 tq?
Old 11-10-2015, 08:17 AM
cmriv's Avatar
I was once told our engine blocks are incapable of such power w/o F/I.....
Old 11-10-2015, 04:30 PM
marc hanna's Avatar
F/I = forced induction?
You could probably do it.
Old 11-10-2015, 10:27 PM
2014 BMW M235i
It's can be done with Cams, Headers, and Tune. That is a lot of money for small returns but can be done.
What work do you have done that allows you to estimate 400hp/430tq?
Old 11-28-2015, 11:45 AM
2003 E500 swap
Well I wish I had pictures, but mainly I did a lot of work on the heads by hand. I use to build v8 for racing. I'm only guessing but the tq for the trans is really giving me a problem at the moment. plus the traction control even off still doesn't like my mods. lol. right now i'm in tx and its good to run on the high ways. I have hit a bigggggg issue. while running one night at a passing speed.... had to get on the brakes. was not happy. Yes I admit, this can be a lot of money. I make most the parts my self and do all my work. This car is starting to lose the comfort of the Mercedes. I started this car for a road course and it does really well, But who doesn't like power. So here is the plan now that the 5.0 is about done. I have a 76mm that I plan on putting in the area where the second battery was. Problems.... air intake, heat etc. with a e55 engine swap and using a Dakota bell housing(haven't put my hands on it yet)hopefully it will mate up to a t56. I can start making big power.... It's not the engine that is the problem its all the damn electronics.
Old 12-01-2015, 04:37 AM
2014 BMW M235i
I have to be honest, I understood maybe 10% of what you were trying to say
Old 12-04-2015, 10:50 PM
NBDT's Avatar
2004 E500 (W211)
I have an E500 and have these current mods: OE Tuning Stage 1 & 2. The second tune just makes the rest of the exhaust components play well together.
MBH Motorsports long tube headers. A definite increase in mid to upper RPM range on the highway.
NeedsWings dual cold air intake. This was custom fabricated by Rob at NeedsWings. This company builds stellar cold air intakes that really work. The fabrication was done over a several week period on a customer's E500. Rob also provided dyno sheets noting gains before and after. A definite increase in lower to mid RPM range.
I'm considering a straight pipe to complete the exhaust modifications. Overall, I'm very pleased with the results.
Old 12-05-2015, 03:34 AM
2014 BMW M235i
Dyno results?
Old 02-13-2016, 07:05 AM
NBDT's Avatar
2004 E500 (W211)
Here's a pic with the NeedsWings dual intake installed. The other pic is the dyno sheet Rob at NeedsWings provided from the "build" car that was used to make my intake. Again, Rob said he has made these for the 55 but not the 500, until now.
I don't haven't ran my car on the dyno with my mods yet, so I don't have a pic of that.
NeedsWing dual intake installed on my vehicle. This is just prior to getting the MBH Motosports long tube headers installed along with a resonator delete and straightpipes while retaining the stock mufflers.
Old 02-13-2016, 05:38 PM
2014 BMW M235i
That looks really good, I could see practical benefit since you are tuned.
Old 02-15-2016, 08:18 AM
cmriv's Avatar
Wonder if the M273 could be something he could fab up. This has my interest.
Old 02-18-2016, 09:57 AM
NBDT's Avatar
2004 E500 (W211)
I have a OETuning stage 2. According to OETuning, the "stage 2" enables the the dual intake, long tube headers and straight pipes to play well together without in-dash error codes. The benefits of the OETune were already noticeable at stage 1.
Old 02-18-2016, 02:21 PM
cmriv's Avatar
So you get stage 2 when you have all the other components installed?
Old 02-21-2016, 12:15 AM
rtbrjason's Avatar
07 E550 4M - 11 Audi TT - 99 Expedition EB
Those dyno results seem ridiculous. Intakes are rarely a restriction and almost never make more than a few hp. In most cases, they lose a few hp. I'm fairly certain you're not adding significant power to an E500 without boost.
Old 02-21-2016, 04:07 AM
2014 BMW M235i
^That's kind of my line of thought. Few NA engines really afford you the ability to mod them cheaply without forced induction.
Old 02-21-2016, 08:18 AM
a100steaksauce's Avatar
W218
this
Old 02-23-2016, 03:40 PM
cmriv's Avatar
Originally Posted by a100steaksauce
this
I'm actually going to reach out to a bud that owns his own fabrication shop and pick at his brain a little to see if he could come up with some ideas.
Heres the link to his website if you want to chat with him. I'm local to him, sorta, so if i have to i'll be the test dummie.
http://www.zuryfabrications.com/
Old 02-24-2016, 04:16 PM
W218
PM'd
OK sounds good. I'd definitely be interested in an intake for the right $.
Thanks I will check out the site.
Quick Reply: E500 upgrades and tuning.
