where is the air temperature sensor w211 220cdi facelift
do i have a air temperature sensor?, if yes, where is it located?
the car is a w211 220 cdi 2008
it is the same as this
http://www.ebay.ie/itm/MERCEDES-BENZ-E-CLASS-COUPE-E-220-CDI-FROM-2010-AIR-TEMPERATURE-SENSOR-LEMARK-/171947141098?hash=item2808d927ea:g:EP8AAOSw0HVWBKR U
If you are talking about the engine air intake air temp for your VIN--then look to the MAF which senses air intake temp\volume as a function for the ECU.
Received 1,729 Likes
1922 Ford Model T / no OBD
The one on ebay looks like pre-MAF sensor.
You have engine that never made it to USA and not too many European members here.
Knowing your location would avoid lot of guessing?
Received 4,415 Likes
'71 Pinto
Intake Air Temperature Sensor 0005422818 should be located on the intake manifold.
Manifold Absolute Pressure (MAP) sensor 0061539928 provides manifold pressure information to the vehicles Engine Control Unit (ECU).
have any changed it, and knows how long time it takes?
Thanks agains
Regards:Lars
