E-Class (W211) 2003-2009
The screw on quantity control valve
Old 11-23-2015, 08:21 AM
larsianer's Avatar
w211
what is the screw on the quantity control valve for,adjusting idle???
the quantity control valve is the part called y94 on the picture,its located on the high preasure pump
is it possible to take it apart, and clean it??
Regards:Lars
Attached Thumbnails The screw on quantity control valve-quantity-control-valve.jpg
Old 11-23-2015, 01:06 PM
Plutoe's Avatar
Received 1,019 Likes on 947 Posts
1999 E300TD
Whats you VIN!!
Old 11-23-2015, 01:14 PM
larsianer's Avatar
w211
Originally Posted by Plutoe
Whats you VIN!!
Hey
My VIN is:WDB2112081B281033
Old 11-23-2015, 01:31 PM
Plutoe's Avatar
1999 E300TD
Y94 regulates the rail pressure and thereby improves the efficiency of the high pressure pump--the regulation instruction comes from the ECU.--imagine the rail conditions at idle, 100kph and 200kph
PS: and please don't take any idiots advice to screw with the adjustment!!
Quick Reply: The screw on quantity control valve
