Key or EIS Failure
Key or EIS Failure
I am in a situation I can't seem to figure out. I have 2006 E500 4Matic with 130K miles. I recently had a situation where my key would turn in the ignition. I tried the steering turning to see if it free the key and that didn't work. I tried the gear shift to see if it wasn't it park and that didn't work. I finally jump started the car and it worked right away. The car started. Therefore, I thought I had a bad main battery. Bought a new one and didn't work. Same problem. Tried to jump start again and it worked right away.
Therefore, I am thinking I have a bad EIS. If I had a bad key, my thoughts are it should work at all, even when jump starting. So before I go to the dealer and drop a lot of money on a car with 130K miles on it, any suggestions on how to isolate the problem myself and change it out? Can I buy a used EIS + keys and fix this myself?
The only way I know how to test the ignition system is via the MB diagnostic software DAS Xentry----and remember the EIS is a theft relevant part(some dealers won't sell TRP retail----then you will need the use of DAS Xentry to properly install the EIS--
My point is it won't be easy without the tools!!
Received 1,729 Likes
1922 Ford Model T / no OBD
You lost me in your description.
The key turned in the ignition, but the starter did not engage?
That is the symptom of computer sensing too low battery voltage and since jump solved the issue, that confirms low battery. Did you clean clamps while installing new battery?
Display car voltage on the cluster and than compare how it changes when you turn on all the headlights.
No need to drive to Florida for DAS to do easy voltage testing.
If that doesn't confirm, then you worry.
My point is it won't be easy without the tools!! __________________
I ordered a new key from dealership and it solved the issue. The dealership discovered that if they held the lock button, the key would turn in the ignition and start.
Thanks for the inputs and problem solved for now.
Jay Intha (04-11-2018)
And they did all that without DAS?
Darn spammers they always try to sell you something you don't need.
Good to hear the car works fine again.
frankly AMG - Plutoe is known to me for at least 6 years.
He was annoying different members on benzworld before they ban him.
Pretty evident he is having benzworld withdraws and take them on me.
That beside the fact that I am not easy on spammers, but since he was not spamming on benzworld, I did not have issues with him there.
Bottom line, this is another to the collection of Plutoe's misleading advises.
How low can you go to make a buck?
2013 ML350 Bluetec
Or not.
