E-Class (W211) 2003-2009
How to replace the SBC pump on a w211
Old 03-09-2016, 06:32 PM
rapidoxidation's Avatar
2013 ML350 Bluetec
Originally Posted by CDIJeff
The 59 million is the total amount of times the pump has been used such as accuations. It took 11 years to to hit 11 million. So I could say that, yes that if you hit the 59 miliion you might get a red light however the SBC would be so old almost positive it would fail before that. The second number 18100 is the pedal count. I just didn't take a photo before I swapped out the pump to see my old pedal count.
The pump is activated 2,700 times a day?
(11 years, 11,000,000 "uses")
Is that revolutions of the pump motor? I'm trying to understand the significance of these numbers...
Old 03-11-2016, 02:35 AM
leafdude555's Avatar
E55 Wagon
I read that you need to code the new SBC pump to your car through the control unit adaptations menu. Can you confirm you didn't have to do that?
Old 03-11-2016, 08:57 AM
jhorandc's Avatar
MB E320
http://www.benzworld.org/forums/w211...ntrol-sbc.html
I have seen references to the SBC having a finite life based on x actuations. How does this value relate to the 59 million from above?
"The SBC has a finite life (300,000 actuations) so sooner or later you will need a new one."
Old 03-11-2016, 10:07 AM
kajtek1's Avatar
Received 1,730 Likes on 1,380 Posts
1922 Ford Model T / no OBD
When I have never seen official MB document about SBC push count, from what some technicians post here, there is no firmly set number of pushes.
Variations are between 500,000 and 600,000 pedal pushes, what brings me to conclusion that other factors make the difference aka pump activation, maybe time and who knows what else.
Now think about pump activation.
Each time you open the door after longer stop- the pump activates. Each time there is moisture on brakes - pump activates. Also when you keep brake pedal coming slowly to stop - you fan it to some degree, so pressure is depleted and pump might have to come several times with single brake push.
That is why pump activation are coming to high numbers.
Old 03-12-2016, 06:52 PM
Gersh320's Avatar
E320 & X166
Awesome!!!! I have access to XENTRY and will do it one night after work. I have the message but am dragging this out. I officially know it is the SBC time frame expired but am wondering about how much longer I actually have before it goes out completely?
Old 03-14-2016, 11:51 PM
diesel315's Avatar
E320 CDI, Jetta 06 TDI, GLS450 20, Boat:2 Volvo TAMD75+1 Kubota genset
SBC really looks like it only has 3 common fail modes. Count, pressure reservoir(easy diy) and the motor itself (brushes are only real wear item, maybe change bearing also while motor is open).
Internal hydralics are in fluid bath and do not seem to fail (but are monitored anyway)
The one seal to the outside, motor shaft, never seen leak, they do weep.
We need somebody to document the brushes in motor and we are all set.
Also, i think it is super important to properly flush this system to avoid leaving air in emergency circuit, which kills breaking power in backup mode. Not a problem when pump is running as system has unlimited pump volume available. Star has a test for air in emergency circuit.
Old 03-22-2016, 09:42 PM
  #32
jhorandc's Avatar
MB E320
Purchased Mercedes Benz reman. SBC online for about $817 ($970 - $153 old core return). Part arrived in a few days in a MB sealed box. Dealer prices for same reman. part ranged from $1070 to over $1300.
Old 03-23-2016, 07:33 AM
  #33
hangit06's Avatar
2006 E320 CDI
Can you post link to site? Thanks.
Old 03-23-2016, 08:20 AM
  #34
Former Vendor of MBWorld
FCPEuro's Avatar
Mercedes
My SBC Units are priced in that range and carry our lifetime replacement
https://www.fcpeuro.com/products/mer...320-0094312512
--Kyle (kyleb@fcpeuro.com)
The following 2 users liked this post by FCPEuro:
forcedawd (05-13-2016), hangit06 (03-23-2016)
Old 03-23-2016, 08:46 AM
  #35
2MERKS's Avatar
'99 CLK/05 E500 WAG
Excellent, Not as scary as before, you should do up some cards, and you could make some
side money.
Old 03-23-2016, 01:56 PM
  #36
jhorandc's Avatar
MB E320
Sites:
mboemparts.com
huskerparts.com
Old 04-04-2016, 03:46 PM
  #37
Gangrene3075's Avatar
03' Mercedes-Benz E500
Is it possible to use the iCarsoft MB II instead of the Star/Multiplexer for this procedure?
Old 04-05-2016, 11:25 AM
  #38
CDIJeff's Avatar
2005 E320 CDI
Looking on google its 50/50 you can try if it works it works. Otherwise the Multiplexer is the error proof way. Also I don't see a way to bleed the brakes from that unit.
I know a while back when I was looking up multiplexers I came across a German forum and the person used a DS708, No idea if it worked. Also that looks really similar to my X431 Creader VIII
Gangrene3075 (04-06-2016)
Old 05-12-2016, 01:25 PM
  #39
mhebb123's Avatar
2006 CLS500
iCarsoft MBII
Did you ever try this with the iCarsoft MB II?
Old 05-12-2016, 01:37 PM
  #40
mhebb123's Avatar
2006 CLS500
Pressure reservoir (accumulator) replacement
I have a bad pressure reservoir. You state that it is an "easy diy". Do you have a procedure for that?
Old 05-12-2016, 02:26 PM
  #41
konigstiger's Avatar
Received 4,415 Likes on 3,145 Posts
'71 Pinto
https://mbworld.org/forums/e-class-w...placement.html
Old 05-18-2016, 08:44 PM
  #42
Xattica's Avatar
2013 SLK55
Hi. Did you install the same SBC item number or a different one? I noticed that the last three number change (eg 0 265 960 XXX).
Old 05-19-2016, 01:18 PM
  #43
Gersh320's Avatar
E320 & X166
I just ordered: 009431251260 for my 2003 E320
Old 05-20-2016, 08:15 AM
  #44
isthisit's Avatar
2006 E320 CDI
Awesome. awesome. awesome. Thank you for documenting this process. Really well done.
Old 05-22-2016, 02:25 PM
  #45
CDIJeff's Avatar
2005 E320 CDI
The numbers changed I just got a vin match one from the website. Really the numbers mean nothing to us just vin match it with a reputable company or dealer. Then you will be fine.
Old 05-30-2016, 10:19 AM
  #46
FCPEuro's Avatar
Mercedes
If you need a verification of the correct SBC unit, feel free to PM me your VIN. This memorial holiday FCP is running a 10% off orders over $199 promotion. You can use the code in the banner on checkout and keep in mind these items include free shipping, lifetime replacement warranty and unlimited returns. Have a safe holiday
--Kyle
Old 07-15-2016, 02:52 PM
  #47
avtodiagnostica's Avatar
Mercedes Benz E63
Thank you very very much!!!
Old 07-30-2016, 04:33 PM
  #48
I bought the MB II but it only turns off the SBC. The brake bleed option is not available for the W211 yet.
Old 08-14-2016, 10:45 PM
  #49
jamusa's Avatar
if i understand you guys correct,are you saying that inorder to change that constant running sound that your brakes makes,its not as simple as just changing the sbs motor/
Old 08-31-2016, 08:20 PM
  #50
nivram13's Avatar
E240 -2003 E55 AMG -2005
I deactivated and bled the brakes with this unit.
http://www.ebay.com/itm/Electronic-P...QAAOSwT4lWREbv
Quick Reply: How to replace the SBC pump on a w211
