Machine Screws and/or Sheet Metal Screw for License Bracket?
I just got the 2118170378 bracket without mounting hardware. It's the bent bracket that goes on on nose of the front bump.
The bracket likely mounts using ~6 mm sheet metal screws that taps into the bumper (say 25 mm long).
What screws to use to mount the license plate to the bracket? Holes will need to be drilled.
Looks like a 6 mm diameter.
The bracket is made of 2.5 mm thick ABS plastic, so not much to hold the screws.
The rear plate is held by 6 mm x 10 mm machine screws.
Dave
2009 e320
Dave
2009 e320
Received 4,415 Likes
'71 Pinto
EPC shows molding to bumper OEM part # 2029900121 (5x18) shown here https://www.ecstuning.com/Search/Sit...121/ES1726976/, 0019904236 plate to molding (5x12) https://www.ecstuning.com/b-genuine-...ch/0019904236/
dave2001auto (05-25-2016)
All my other cars had plastic expanding mounts for the screws.
