Car is blowing hot air for minutes before cold air comes
Location: In the northern parts of Sweden, in a town called Boden
w211 e320cdi, w124 250d, w115 220d
Hello and sorry for my not so good english (im from Sweden)
I have an w211 touring 2005 e320cdi with v6. 410000km
When i start my car, and set the temp to 19 degrees celsius, it blows hot air in sometomes 10 minutes before it starts to come cold air. but when the cold air is blowing, it is really cold.
What can be the problem?
Does this have anything to do with the duo valve?
/Stefan
/Stefan
Received 1,730 Likes
1922 Ford Model T / no OBD
If you have climatronic with REST button, you can read sensors on it, if not you need to use SD scanner.
Most likely one of the sensors is bad and readout at different car temperatures should point it.
i have rest button and climatronic. how do i read sensors? Thanks for tip though =)
If it blows hot air, it sometimes helps to shutdown, and restart car, then it comes cold air, very strange!
