H7 Led Bulb Install Help
2005 Mercedes E320 CDI
Can anyone help me with advise on how to install H7 led bulbs in a 2005 E320. I took out the factory bulb but there is a metal clip that holds the factory bulb in place. But that metal clip will not work on the led bulb because of the size of the bulb fan. Any advise? Thanks everyone
I installed Leds to my headlights on my w211 however I switched my projectors to D2s from the H7. I couldn't find a way to get a h7 led inside the clip and connect it into place. The new bulbs are brighter then the factory halogen. Wish I could get a set of the Morimoto LED led headlights to compare to my mine.
https://mbworld.org/forums/e-class-w...ml#post6809965
OR, if you have one of those two piece bulbs with the threaded collar, you can install the collar first with the retaining clip. Then thread the bulb into the collar. Do this before you connect the wiring so you don't twist it up.
W204 C63 AMG, W212 E250 CGI, C207 E250 CGI
when i converted my 211 to HIDs, i cut the clip so i can reuse it with the new HID bulb. but it didnt come with a buiilt-in fan like you mentioned above.
2013 ML350 Bluetec
HID is not equivalent to LED. Some models of LED lamps have a fan built on to the tail (where the plug normally is) to keep the LED element cool. Some have a copper wick. I believe ALL of them need some external heat sink, passive like the wick or active like the fan, to handle the heat load.
2013 ML350 Bluetec
Hopefully the OP will come back and tell us his solution. I don't know the answer to your question, but I'm curious. I've got H7's on my Ducati and it'd be nice to have a (much) brighter light in there than the OEM halogen. Same deal though: There's no way an LED wick much less a fan would fit inside the housing.
Trying to replace my 2004 E320 Headlight with LED and found this. https://www.xenonhids.com/mercedes-benz/2004/e320.html
Is this good buy?
I assume you also need warning canceler?
Can anyone familiar with this help me to choose?
Thanks in advance.
Is this good buy?
Thanks in advance.
