Struggling to start after sitting for a few days
W211 2008 e350
So my 2008 e350 4matic (118k) has been struggling to start after sitting for a few days. It's pretty linear, meaning the longer the wait, the more turns it takes to start. I initially thought it was a battery drain, so I got a battery tender. Check the voltage before starting, usually ~12.5.
Any other suggestions, this has been going on for about a year.
I also leave the key in the second position before starting for 30 seconds or so, to let the fuel pump - makes no difference.
Any other ideas what might be wrong?
Received 1,730 Likes
1922 Ford Model T / no OBD
Is it 12.5V on cluster or on battery terminals?
12.5V battery is low, but clusters tend to show lower readings.
In your case the first troubleshooting coming to my mind is checking fuel pressure.
Fuel pressure gauges cost $19 at HF and takes only seconds to hook up.
W211 2008 e350
On the cluster, it's the same voltage as when I turn the car off. I'll get the fuel pressure checked.
W204 C63 AMG, W212 E250 CGI, C207 E250 CGI
just saying, all my cars have dashcams on em and are set to turn off (parking mode) when battery hits 11.5V. came back a few times with the camera off after sometime so i figured charge is down to 11.5V. no issues in starting whatsoever.
so in your case, 12.5V should be more than enough i reckon. have you had the starter looked at? its been on for a year and you havent had it checked? you dont wanna get stuck in the worst place.
also, +1 on kajtek1's advice.
W211 2008 e350
