E-Class (W211) 2003-2009
W211 CDI low high end power + blk smoke
Old 01-14-2017, 09:29 PM
Cdibraj's Avatar
2005 W211 e320 cdi
2359-1: check charge system, too low boost pressure.
2011-1: Check component B2/5 (hot film mass airflow sensor) Sensitivity drift air mass ratio for calculated quantity (top)
Via my icarsoft MBII; changed MAF unit with the built in Bosch MAP sensor. No difference. Only goes into LIMP when the RPMs pass 3000 and that is when the loss of power is noticeable along with black smoke.
The icarsoft is good for reading values its just I have no idea if something is working as it should be or not, if anyone has a list for the car's "normal" values so I can see the range my w211 should meet, I'd appreciate it.
As of right now my guesses would be an air leak somewhere, or the sensor thats in my CAT/DPF? Thought I'd get an opinion before i wasted money on parts I dont need.
Old 01-14-2017, 11:30 PM
PSDCampervan's Avatar
2005 E320 CDI (SOLD); 2008 ML320 CDI 4MATIC
If your vehicle is a 2005 with a om648 I6 engine, I don't think it should have DPF. SCR/DPF emission devices didn't start showing up until 2007 with the facelift w211s & introduction of om642 V6 engines.
Old 01-14-2017, 11:38 PM
Cdibraj's Avatar
2005 W211 e320 cdi
There's a filter in the CAT for sure, maybe its not called DPF but there is, its just not cleaned with that fluid used in bluetecs but through heat.
Old 01-15-2017, 11:23 AM
ptkacik's Avatar
2005 E320 CDI
I have an '05 CDI and it runs great. Years ago, I had a turbo Porsche and one day it ran poorly. It turned out to be a very torn rubber intake hose. In the days of carburetors, it wouldn't have run at all; however, with all the electronics tuning the injection it just ran poorly.
FWIW, Look carefully at your intake plumbing for visibly damaged parts.
Peter
Old 01-15-2017, 01:21 PM
Cdibraj's Avatar
2005 W211 e320 cdi
Yeah its def a leak imo, I also have a Merc Sprinter with the inline 5 thats at 300k miles and inly issue with that baby has been cracked rubber hoses. I have the idle values for the oxygen sensor (1.9v on avg) , and MAF (20g/s on avg). I have an s350 bluetec and i know the engines and all that are different but can I compare the ratios of that with the e320 cdi?
Old 01-17-2017, 09:54 PM
DubVBenz's Avatar
W212 M276 DELA 30 ; W211 OM642 ; R107 M117, Sierra 1500 LZ0
As our new president would say... WRONG! OM642s in the W211 ONLY had a DPF (diesel particular filter.. cleaned through heat.. aka REGEN). CDIs from 2005-2006 ONLY had Cats. OM642s in W212s had DPF + DEF (Urea).
Old 01-17-2017, 09:59 PM
DubVBenz's Avatar
The W221 S350 Bluetec is an OM642 with DPF + DEF , along with a new head and water cooled turbo. Your sprinter with an inline 5, depending on year, is most likely an older diesel that has absolutely NONE of that post treatment equipment.
The W211 Facelift from 2007-2009 is an OM642 with a DPF only and an older head and turbo setup, resulting in lower power output.
Please take your vehicle to someone who understands it before you destroy it.
Old 01-18-2017, 09:52 AM
Cdibraj's Avatar
2005 W211 e320 cdi
Well then you and your new president must be both idiots because i know for a FACT it has a dpf filter IN the CAT because I have removed it and brought it to a professional diesel filter cleaning shop. Its a beehive like wooden material inside. Dont comment unless you can help.
Old 01-18-2017, 09:57 AM
Cdibraj's Avatar
2005 W211 e320 cdi
W211 05' CDI
CAT w/ dpf inside
Quick Reply: W211 CDI low high end power + blk smoke
