Last edit by: IB Advertising
See related guides and technical advice from our community experts:
- Mercedes-Benz E-Class: How to Replace Your fog Lights
Step by step instructions for do-it-yourself repairs
How to change the fog light bulb in W211?
Hey guys:
I am new to the forum also a newbie to own an E class. i am wondering how to change the fog light bulbs since in the owner's manual, it states that requires dealer service. Any one on the forum has gone thru that, procedure or photos? Thanks in advance.
C200K (w204)
Not sure about E, but i'm pretty sure it's similar to C class. Basically wat u need to do is to remove the inner fender lining by removing some clip. After it has been removed, it's a breeze, just twist and unplug i suppose.
2005 E500
Originally Posted by rayster
Hey guys:
Here is my quick description on how to change fog light bulbs on an '05 E500. Now if you have an AMG W211. This description probably would not apply as I know the AMG's have a completly different bumper and set of fog lights.
Good luck! Let me know if you have any questions.
The fog lamps were probably the easiest to access for the swap. No need to jack the car up. Slide your head and a good flashlight under the front bumper directly under where the fogs are located. You'll see a plasctic panel the runs the entire length of the bumper, directly under the location of the fogs there are "pre-cut" access panels that are held shut by to small plastic screws that when turned a quarter turn will allow the access panel flip open, reach in and swap the bulbs.
cheers,
J-
