Bulletins 207 coupe & 212 sedan
#251
Received 4,415 Likes
'71 Pinto
Service Campaign 2015110001 NOV15 – 2015 & 2016 212, 218, 242 Audio 20 when saving 26th HD radio station logo head unit begins reset loop. Update control module software. Approximately 22,156 vehicles affected.
LI68.50-P-062299 NOV15 – 212 wagon, load compartment cover does not move upwards when tailgate is opened, magnet is integrated in right guide pin detected by sensor in guide rail. Check if magnet is installed (image shows magnet not present).
LI91.30-P-062537 NOV15 – 212 (w/designo equipment only) front seat heater wiring is visible, remedy is being developed optimized parts will be available shortly.
#252
'71 Pinto
Recall 2015110006 DEC15 – 2014 212 incorrect fuel line installed, dealer will replace. Approximately 809 vehicles affected.
Service Campaign 2015120001 JAN16 – 2012-2014 117,166,172,204,207,212,216,221,231,251 fuel system control unit fault memory behavior may malfunction leading to incorrectly displayed diagnosis results or the inability to delete results, dealer will update CU software. Approximately 68,535 vehicles affected.
LI83.30-P-062887 DEC15 – 222/212/205 hybrid insufficient AC cooling output, perform leak test of refrigeration circuit of high voltage (HV) battery, replace HV battery.
#253
Don't blast me!
I love this thread and really wish they had one in X204 section. I have a clunky upshift from 3-->4 on no/very little throttle on 2015 GLK350 with 7G Plus. Would love to take a TSB in to dealer - they claim all is well.
#254
This is an awesome thread, I should subscribe and stay on top of these.
Does anyone know if the repairs for the service bulletins only apply during the initial warranty period? How about with MB extended warranty?
I will be checking with my dealer as well. They did replace free of charge two seat back shells on the driver and rear passenger seats that have cracked along the thread lines. That was on a 2011 last year (2015). The original warranty was expired and I was told the MB extended warranty we purchased did not cover it. They had to review it and agreed to replace free of charge which was very generous of them. The light grey mb-tex covers had to be shipped in from Germany as apparently there was none in stock anywhere in the US.
#255
Great thread! Thanks for the info, just subscribed.
Could you let me know which service bulletins, campaigns and recalls affect my 2014 E350 4Matic? VIN WDDHF8JB6EA883898.
so far I only found: "LI62.25-P-056043 JUN13 – 212 & 218 deformation of engine compartment soundproofing due to water ingress. Install optimized seal part # 2126280800" Like others have said, looks like someone took a picture of my engine bay.
Thank You
Thank You
#256
2010 E550 P2 w/AMG Sport Package + Pano, 2015 Nissan Pathfinder
Service Campaign 2012070002 SEPT12
Models 164, 171, 203, 204, 207, 209, 211, 212, 216, 219, 221, 230, 251, 463 Engines 272 and 273, MY 2005 – 2011 Camshaft Adjustment Solenoids - due to the settling properties of the seal, oil may leak from the camshaft adjustment solenoid dealers will retrofit four adapter harnesses onto the engine wiring harness. Covers any/all repairs due to damage from oil leak however, claims replacement of leaking camshaft solenoid is not permitted under consequential damage. Approximately 557,108 vehicles are affected - have dealer check VMI to determine if vehicle is included.
#257
'71 Pinto
LI27.20-P-063110 JAN16 – 278 up to MY14 after a shift is performed under medium load a slight shudder is felt, low slip speed of torque converter lockup clutch allows engine firing order to be felt through driveline. Update software. Vehicles MY15 and newer have been produced with the software solution.
Brake juddering/shuddering felt when braking, replace linings & discs:
LI42.10-P-063149 JAN16 218.391 (cls500 4matic) rear
LI42.10-P-063150 front
LI42.10-P-063151 JAN16 – 212.091 (e550 4matic) rear
LI42.10-P-063152 front
LI42.10-P-063153 JAN16 – 212/218 (sport 951) rear
LI42.10-P-063154 front
LI42.10-P-063156 JAN16 – 212/218 w/brake dimensions 300x22 mm rear
LI42.10-P-063155 JAN16 – 212 w/brake dimensions 344x32 mm front
LI42.10-P-063157 JAN16 – 212 w/brake dimensions 320x24 mm rear
LI77.00-P-063147 JAN16 – 207 Cabrio chirping/rubbing type noise just before roof fully closes, seal in affected areas and Insert filler foam into seal channel (see photos).
jumpman726 (08-07-2016)
#258
Service Campaign 2009070001 JUL09 to properly re-calibrate daytime running lamp operation, a software calibration number (SCN) update must be installed.
LI68.50-P-047173 JUN09 roller blind motor does not start at extremely cold temperatures, dealer will perform SCN coding to rear SAM increasing current to 8A.
LI80.61-P-047297 JUL09 anti-theft alarm system (ATA) activation after keyless-go (KG) unlocking via a door handle, update software to KG control unit.
LI68.10-P-047474 JUL09 rattling/vibrating noises at center IC/speaker cover because of production tolerances, felt will be installed.
#260
'71 Pinto
Service Campaign 2016010006 FEB1 – 2015 212 digital Owner’s Manual may not be loaded & CD-ROM not present dealer will load & supply CD. Approximately 622 vehicles affected.
LI91.10-P-063385 FEB16 – all models front drive & passenger seat creaking/grunting when pressure applied to backrest, tighten 4 bolts of seat height adjuster to 50 Nm torque.
LI91.10-P-063393 FEB16 – 117, 156 before VIN A27110 on 212, 166, 172, 204, x204, 246 splitting of seat, replace as needed (see below).
LI82.85-P-063619 MAR16 – 212, 218, 117, 156, 176, 207, 242, 246, 292 w/code 531 COMAND displays 2035 date, internet radio inoperative, and/or free browsing inoperative, remedy is being prepared in the meantime can be rectified by resetting COMAND date via Xentry.
#261
Thanks a lot kingtiger!
Im new to bulletins and cant determine how it works.
I have splitting in my seat in my car (WDD2120031 A080969), just as LI91.10-P-063393
Would my car be covered then?
#262
'71 Pinto
Xentry bulletins are only covered under warranty i.e.: initial factory or extended. However, in this case as it applies to your 212 because the bulletin documents a known problem (defect) within a specific VIN range “before A27110”. Since A080969 is within range reference bulletin to service manager and request he/she contact MB to see if they will approve goodwill assistance unless you have a MB extended warranty then it should be covered.
Note, no reference to leather or MBtex surface therefore as it currently reads it should apply to both.
#263
'71 Pinto
I was thinking A271100
#265
To Konigstiger,
Since upgrading to Win10, I can no longer get access to EPC to pull up my Data Card. Something to do with Java and Edge and IE11?
Would you be kind enough and look up my Data Card for:
WDDHF8JB2EA821673
Thank you in advance.
WDDHF8JB2EA821673
#266
'71 Pinto
Certainly.
Firestopper0383 (03-19-2016)
#268
I've seen your name here since I bought my first Benz in 2003 and now I'm on my third and all is wanna say is Thanks Konigstiger for all your insight. Question for you ,how can I turn my avatar right side up??
#269
'71 Pinto
Move from Jersey - plenty of relatives there Middletown, Jackson. Matawan, Manalapan… Anyway, image needs to be right before downloading to profile.
#270
Be kind Dan Long Branch and the area you mentioned were my old stomping grounds before moving to South Jersey. Yeah, I'm one of those 609'ers.
#271
'71 Pinto
LI80.35-P-063677 - All models Keyless-Go DAS4 (2007 >) “Replace battery in transmitter key” reappears in instrument cluster within a few days after replacement, update KG control unit software/perform SCN coding. FYI if key enters passive mode resulting in no feedback from key during KG engine start key can be reset by removing battery.
#273
'71 Pinto
LI00.20-P-063991 MAY16 – 2012 212, 207 service display prompt shows same service (A or B) twice in succession, update instrument cluster.
#274
Mercedes Hard to Find Parts .. Cheap!!
#275
'71 Pinto
Service Campaign 2016050001 MAY16 – 2016 207 Cabriolet A-pillar seam may allow moisture ingress, dealer will seal. Approximately 415 vehicles affected.
LI82.60-P-064266 JUN16 – 212/218 with Audio 20 (505, 520, or 522) switches itself off and on without cause & telephone menu cannot be activated, flash headunit and SCN code.
LI09.40-P-064267 JUN16 – 651 engine rattling noise from front of engine on left in area of turbocharger for a short time after cold start, replace air duct housing.
