Bulletins 207 coupe & 212 sedan
#178
Received 4,415 Likes
'71 Pinto
Service Campaign 2013100005 NOV13 – 2013 204, x204, 207 seam seal on the under-floor may have been damaged during manufacturing process, dealer will repair. Approximately 1,664 vehicles affected.
Service Campaign 2013110002 NOV13 – Model years 2011-2013 166, x166, 172, 204, x204, 207, 212, 216, 218, 221, 231, 251 fuel system control module software does not correspond to current production configuration Check Engine Light (CEL) may occur, dealer will update software. Approximately 123,831 vehicles affected.
Service Campaign 2013110011 DEC13 – 2013 212 Hybrid Operators Manual may not have been installed, dealer will install. Approximately 11 vehicles affected.
LI88.60-P-049559 APR12 – 212 fuel filler flap deformed, opens/closes poorly. (1) Paintwork does not cover entire area of attachment point between rear of fuel filler flap and filler flap arm, substrate absorbs moisture at this point. (2) The retaining strap can become twisted from opening the tank filler cap this can cause the retaining strap to wedge behind the hinge arm obstructing closing sequence. The height of the stop buffer located on the left of the tank recess can impair the opening and closing behavior of the fuel filler flap. Remedies: cut off stop buffer on the left of the tank recess as this will help to improve the opening and closing behavior, replace filler flap.
LI88.70-P-056690 OCT13 – 212 (code(803) outside mirrors can fog up at outside temperatures below 15 degrees C (60F) up to production 1/2013 heated mirrors are actuated only 10 minutes after engine start, code front door control units so mirrors are actuated continuously.
LI46.35-P-057738 NOV13 – 212 4matic & 212 AMG facelift (804) with direct steering (211), battery discharged. DS control unit does not switch to idle state when vehicle is locked, update software.
LI54.25-P-056472 NOV13 – 166, 204 (GLK only), 212, 218, 246 key is not recognized vehicle cannot be started and/or transmission shifts to “Automatic P”, replace electronic ignition switch (EIS).
LI80.61-P-057752 NOV13 – 212 VIN A909083 – A920630 & 222 A020500 – A023037 Keyless Go (889) vehicle cannot be opened/closed or started via KG manufacturer fitted key with wrong processor. KG function worked in the past - yes, perform diagnostics; no, replace affected key.
LI27.19-P-057771 DEC13 - 212.098, 298 Bluehybrid, 095 Hybrid & 222.057, 157 Hybrid various transmission problems including intermittently cannot shift into reverse also CEL may light up. Oil pressure switch is faulty. If problem occurs in combination with fault code P087000, replace TCU.
LI72.20-P-053019 DEC12 – 212.2 up to VIN 663422 & 204.2/204.9 with code 809 up to 942003 automatic liftgate malfunctions (gap dimensions not OK, reverses direction when closing, and/or does not open completely). Jamming of the liftgate lock caused by faulty actuation from rear SAM can bend the left tailgate hinge. Replace hinge and rear SAM.
#179
'71 Pinto
LI72.40-P-058061 DEC13 – 204 & 212 normalization of left or right front door power window may intermittently be lost or automatic window raising not possible, update door control unit software.
LI82.85-P-058185 DEC13 – 166, 204 & 212 with engine OM651 intermittently COMAND display may show fault message “Anti-theft protection activated” cause, disrupted CAN communication.
LI82.61-P-058186 DEC13 – Becker MAP PILOT (code 508 or 509) cannot be operated navigation display freezes, perform software update.
LI46.35-P-057867 JAN14 – 207 VIN 1F 236519 to 249267 (steering gear 2074603100) & 212 1A 831730 to 907236 (2124608900) with direct steering (code 211) except 4matic & 212.#074/75/77 scraping/sqeaking noises when steering quickly from lock to lock in both directions, replace steering gear.
#180
2020 S560 Coupe & 2018 GLS63 AMG
I just bought a CPO 2011 E350 4Matic Sport. I noticed today when sitting idle, the AC/Heat blower fluctuates in speed when set at a level 3 or higher. You don't notice it with the radio on and it is hard to notice while driving with the radio off. But sitting at a light or in park....it blows harder, then softer, etc. I did a Google search and came across a website called eautorepair.com (mitchell's). It shows a TSB that may be my issue, but want you to pay a subscription to see it. So a couple questions:
** Is a site like that worthwhile to pay to use to get access/alerts on TSB's for my MB/
** Does anyone have details of the following TSB: LI83.30-P-056980 · BLOWER OUTPUT OF AIR CONDITIONING FLUCTUATES, LOSES POWER OR STOPS OCCASIONALLY
Thanks in advance!
Thanks in advance!
#181
heater blower
Thanks in advance!
Thanks in advance!
#182
#184
2010 E350 Luxury Sedan, Engine 272 (V6)
I thought the "heated" mirrors were only active when the rear window defogger is activated and it is on a timer.
Haven't experienced this problem on my 2010 even at temps as low as 30 degrees F.
Thanks.
Thanks.
#185
'71 Pinto
Bulletin applies to MY13 (803). Temperatures below 15°C (60°F) the heated outside mirrors are actuated continuously and they can always be activated by turning on the rear defrost.
#186
'71 Pinto
LI46.15-P-058505 FEB14 – 166, 172, 197, 204, 207, 212, 218 creaking noise when adjusting electrical steering column, lubricate thrust piece of steering column.
#187
Major problem : at dealer now and in Bangladesh it is not that easy to deal with this
LI72.40-P-058061 DEC13 – 204 & 212 normalization of left or right front door power window may intermittently be lost / automatic window raising not possible, update door control unit software.
#188
Is that enough to solve the problem
My steering wheel is making grinding noises when car has been increasingly used over a period of a day, is this solution enough to do away with problem ?
#189
Re: seam seal and fuel system control module
#190
Received 1,884 Likes
2014 E63S; AMS 100 octane ecu tune; edok tcu tune; BB intakes; dyno tuned
I had this issue on my first 2014 E550 and they replaced the entire steering column and the steering gear, and the problem went away. I had the grinding all the time though.
#192
'71 Pinto
LI63.30-P-058687 MAR14 – 207 production date as of 9/09 up to 10/10 sloshing noises from area left & right rocker panels / longitudinal members drain water, preserve with cavity wax, and replace grommets.
LI83.00-P-058688 MAR14 – 212 hybrid AC intermittently does not cool, replace evaporator shut off valve.
Service Campaign 2014020004 MAR14 – MY14 212 & 218 weld seams at rear axle cross member may not be to specification, check and repair left & right weld seams. Approximately 1263 vehicles affected. Have dealer check VMI to see if VIN is included.
Service Campaign 2014030001 APR14 – MY13-14 212 hybrid transmission control module software does not correspond to current production configuration, update software. Approximately 342 vehicles affected.
LI72.20-P-054311 APR14 - 212.2 up to VIN 670422 liftgate reaches upper end position, single noise coupled with jerky movement in the left hinge area perform variant coding and normalization of liftgate control unit.
#193
Glad I started lurking on the W212 page! This stuff is great. Looks like it covers my car too (2013 C250 with M271 Evo and 7G Plus). Glad to see I don't have any issues to deal with.
Do you think other auto manufacturers have this many bulletins and recalls? Or do they have just as many problems but don't report at the dealer level?
#194
LI88.20-P-052891 - 212 rear bumper sticks out in area of rear lamp. Bumper experiences thermal expansion mounting rails (fender area) cannot sufficiently hold the bumper in place. If bumper is not equipped with additional latch, it should be replaced. Note since JAN11 bumpers are equipped with additional retaining tab.
While I can feel a slight bump in the front part of the seat, my datacard (thanks again) does not show option 873 even though the car has seat heaters and my vin is below A703331. Perhaps this is specific to a later model year or separate heat seater option.
#195
"It's like you took a photo of my engine compartment. I have this deformation. Since I am out of warranty, should I bother fixing this myself or just leave it? Is lack of soundproofing performance the only downside?"
Wow, Same here! I would like to get this fixed. It's an eye sore to me, but obviously only me.
#196
2010 E63 AMG
#197
'71 Pinto
#198
'71 Pinto
If it were me I would request goodwill replacement. Bulletin documents inferior seal installed at production allows for water ingress causing soundproofing to deform, MB requires modified seal to correct – one can either discuss this with service manager or have CAC (800-367-6372) open a case for review.
#199
'71 Pinto
LI82.85-P-058859 Apr14 – 212, 218, 207, 117, 156, 166, 172, 176, 204, 216, 221, 231, 246 w/retrofitted Drive Kit Plus (DKP) for iPhone 4/4S/5/5S/5C server unavailable or Car-to-X unavailable error may appear when driver wishes to report a hazard manually and heightened security rules have been activated in the system update DKP control unit software in addition, customer should update iPhone app to latest version.
LI82.85-P-058928 Apr14 – MY14 212, 218, 207, 117, 156, 166, 172, 176, 204, 231, 246, 463 Sirius application constantly displays “Updating Channels” audio output from most recent satellite station is present but no other stations can be selected. Complaint occurs sporadically after ignition on following ignition cycle issue disappears temporarily. Press COMAND on button for about 10 seconds this will perform soft reset issue may return after next CAN sleep – do not replace any parts matter under investigation.
LI88.20-P-058905 Apr14 – e63 wind noises area of bumper/engine hood between 45-80 mph, gap between trim and bumper greater than specified dimension remove front bumper and glue chrome frame to ensure stability.
Service Campaign 2014040004 May14 – 2014 E-Cabriolet trunk seam seal may not be to specification, dealer will rework seal. Approximately 55 vehicles affected you can have dealer check VM
LI98.00-P-058914 JUN14 - Exterior clearcoat finish is peeling, flaking, or exhibits bubbles under the surface, improper adhesion of clearcoat. Dealer will refinish affected areas.
#200
Read more: https://mbworld.org/forums/e-class-w...#ixzz33gTQ4HbF
