HomeLink Loses Settings
Old 11-08-2009, 04:35 PM
Steve L.'s Avatar
SL55
I have a 2010 E350. Love it... but twice now the HomeLink has lost all of its settings for opening my gate and garage doors. Has anyone else experienced the same problem. Thanks!
Old 11-08-2009, 06:03 PM
MichaelB.'s Avatar
Barolo S550, 2010 E, 1966 SL & others.
On occasion both my S-class and the 212 E take a few moment before the door will respond, but then after being persistent it will finally function. I can tell you though that it is most likely the garage door opener (mine is a Wayne Dalton and they are notorious for having weak home-link action). Check the door for roaming code capability and confirm that its correctly coded for that first before assuming that its the car.
Old 11-09-2009, 10:11 AM
Steve L.'s Avatar
SL55
The problem is definitely not my garage door, since this affects two garage doors and a gate. As I said, this is the second time this has happened. It will work fine for weeks, even months, then suddenly all three buttons do nothing.
Old 11-09-2009, 10:57 AM
petee1997's Avatar
...21 GLE53 24 GLE53
I had the same problem when I first got my E350. I had to synchronize once a week with the opener. Solved the problem by clearing everything out of homelink and re-entering. Have not had a problem since.
Old 11-10-2009, 12:14 PM
skipper's Avatar
2010 E350 4-Matic, Silver, Blk Leather, P2 package, Sport pkg, Drive Dynamic Seat
It happened to me for the first time last night. Had to reprogram. Hopefully all will be well and this won't be a recurring problem.
Old 11-10-2009, 12:17 PM
skipper's Avatar
Opps...forgot to change my signature.
Old 04-04-2015, 12:57 AM
PHML's Avatar
2011 GLK350 P1, Multi-media & AMG Pkg; 2010 E350 w/ prem 2; 2018 4Runner SR5 Prem. 4x4
Happened to me yesterday...I guess I have to re-program it.
Old 04-04-2015, 03:17 AM
belarus27's Avatar
2010 e550 p2
Same
Old 04-04-2015, 07:56 AM
Alex.currie44's Avatar
2009 SLK55 AMG
Homelink
I agree here. Get your manual out and clear all codes and reset everything according to the instructions in your manual.
As I recall you hold the two outside buttons simultaneously until the light flashes.
Old 04-04-2015, 12:19 PM
Airmousam's Avatar
2010 E550 4M P2 Distronic, CLK550 Cab P2
Happen to me too this week...weird
Old 04-13-2015, 04:14 PM
jsd52756's Avatar
2010 E350 P1 & P2
Happened to me twice. Turned out the soft rubber buttons will occasionally stick in if they are not pressed evenly. It is really not a good design. Need to press them in straight and easy so they don't get cocked at an angle when pressed.
Quick Reply: HomeLink Loses Settings
