Last edit by: IB Advertising
See related guides and technical advice from our community experts:
- Mercedes Benz E Class How to Reset Tire Pressure Monitoring System (TPMS)
Step by step instructions for do-it-yourself repairs
TPMS after tire rotation
Hi Guys,
I just rotated my cars' tires at an MB dealer and after driving back, the tire pressure monitor on the IC said: " Tire Pressure Monitor Active" and it doesn't give tire pressure readings. Is that normal?
Thanks in advance.
Thanks in advance.
1 Post
'11 E350 4MATIC
I am not with the car right now. But if I remember correctly, go to tire pressure menu and hit ok on steering wheel. This will give you tire pressure reading. Hit ok one more time. Then it will ask you if you want to reset and choose yes. Very self explainatory, almost the same as to reset the trip meter. Good luck.
Received 4,415 Likes
'71 Pinto
Sorry to jump on this late. I recently purchased a used 2009 e320 (US). Am I correct in concluding that my car, because it is US, will not actually indicate the actual psi in the tires, like the canadian cars do? All it says is "tire pressure monitor active" when the tires pressures are within limits?
