Is the easy entry/exit steering wheel feature standard on 2011 E350?
2011 E-350
I can see the option and activate it under "system settings" but the steering wheel still won't move when I enter or exit the car. Am I missing anything? Isn't this a standard feature on all 2011 E350? Thanks.
Does the steering wheel move all the ways it's supposed to when you try to adjust it? One of the motors in my steering wheel quit working and needed to be replaced. The easy entry/exit did not work until the motor was replaced.
2011 E-350
OK, I figured it out. We had not adjusted the steering wheel height when we got the car although it was set all the way up (both my wife and I are very tall). Well, it turns out that all the easy entry/exit feature does is to raise the steering wheel all the way up (it does not pull the wheel in). So, if the wheel is already at its highest position, as in our case, nothing will happen upon entry and exit.
Thanks for the replies though. I appreciate it...
