Fluctuating Tach
Old 08-08-2011, 09:39 PM
Grau E350's Avatar
Mercedes product
Fluctuating Tach
I thought this was an issue in 2010 models...but.
I noticed my 2011 at a constant speed like 60 or 65 with cruise fluctuates about 200 rpm. i've never seen a tach bounce up and down constantly.
Is this an electronic issue, or has this been deemed "normal?" in the board's experience. I remember it coming up before with the 2010's.
TIA.
Old 08-09-2011, 12:34 AM
ImInPA's Avatar
2012 S350 Bluetec 4Matic, Diamond White, P2
my 2011 Bluetec does not bounce around. What does your dealer say?
Old 08-09-2011, 02:51 PM
Live Oak's Avatar
E550
My tach is solid as a rock.
Old 08-10-2011, 12:07 AM
Arrie's Avatar
TIA.
Tach moving around can be a sign of a serious issue with the engine. I understand from your post that the engine actually runs fine at constant speed but the rev counter fluctuates, right?
If rev counter signal comes from crank shaft sensor the issue is serious as it means the engine control system would also get the defected signal. This has an effect to all engine control functions.
Old 08-10-2011, 12:34 AM
Grau E350's Avatar
Mercedes product
Thank you very much for the replies. I haven't discussed this with service yet, but I will. I found it incredible odd that this is occuring...I've had a lot of cars over the past 5 years (all German) and this is the first I've seen.
Yes, the tach at a constant speed fluctuates around ~200 rpm constantly. You can watch the need bouce up and down, which is pretty strange.....especially going over a flat stretch of road w/ cruise control.
Old 09-06-2011, 03:09 AM
ghh429's Avatar
MB W212; NISSAN R35; BMW E60
Plug in an OBD ii reader (or get the dealer) to check if it's a problem with the stepping motor on the tach or the RPM sensor (or if the engine is actually revving - you will be able to tell by the airflow).
Some cars idle like crap, some cars don't. My E55 had a bouncing tach too but had good compression and I really was never able to isolate the problem...
Old 03-12-2013, 10:55 PM
T100T's Avatar
2010 E550
Was this matter resolved? I see a slight flutter on the tach when cruising, 2010 E550. No indications of engine issue.
Did you see the below under bulletins...
LI54.30-P-049068 MAR10 – 207 (coupe) up to VIN F014219 / 212 (sedan) to A079696 tachometer fluctuates by approximately 100 rpm, IC will be replaced.
thanks,
Peter
Old 03-17-2013, 09:45 AM
tge4's Avatar
2011 E550 4matic
pwells is correct. There was a service bulletin released about this. Talk to your service department. There is a fix, and its instrumentation, not equipment.
Old 12-19-2013, 12:11 AM
marcosevo's Avatar
Mercedes W211 E200 2008
Tge4, do you have the link to this service bulletin?
Quick Reply: Fluctuating Tach
