Sign in using an external account
| E-Class (W212) 2010-present: E 350, E 550 |
LinkBack | Thread Tools | Search this Thread | Rate Thread | Display Modes |
#1 | ||
Drives: 2011 GLK350 P1, Multi-media & AMG Pkg; 2010 E350 w/ prem 2; 2001 Lexus GS300 VIP Style
Continental ContiProContact Tires SUCK!!
__________________
![]() 2011 GLK350 - P1, Multimedia & AMG Pkg 2010 E350 - P2 w/ 18" AMG wheels 2001 GS300 VIP Style Last edited by PHML; 01-13-2012 at 04:41 AM. |
#2 |
Drives: w212 E550
wow, that's some nasty stuff
! have you talked to the dealer yet?
#3 |
jeez man, that's terrible!! Maybe you got a bad batch, or it's the Hawaiian air!! warranty? dealer? ![]() Let us know how it works out cousin!
__________________
#4 |
Drives: 2012 S350 Bluetec 4Matic, Diamond White, P2
That looks like the type of damage that comes from underinflation heat build up. You can see from the photo that this did not occur all at once but over a period of time. You can see evidence of underinflation on the side of the tire. It is important to check your tires often and regularly. I would go to a Continental Tire dealer and get their take. They will likely assist you. There is something unique to your tires because I have owned cars with that tire and my only complaint with them was excessive noise as they wore down. It will be interesting to see what a tire dealer says. The damage done does not seem to be the tires fault but a maintenance issue.
__________________
___________________________________ 2012 S350 Bluetec 4Matic, Diamond White, P2, Flux Capacitor, Mr. Fusion, and one jar Gray Poupon. |
#5 |
Drives: 1953 300 Adenauer, 1971 300 SEL 6.3, 1975 600, 1978 450 6.9
it also looks like you have been rubbing somewhere and your alignment may be suspect. Is the car lowered?
This isn't a 'Continental' problem and you need to take close look at your other tires. Take ImInPa's advice and seek out a tire dealer rather than the Mercedes dealer and please report back. |
#6 |
Inner and outter part of the tire?.. underinflated.. 30 psi sounds low
#7 |
Drives: S212 2011 Wagon and 2014 C350 sedan on order.
When I ordered my car, I requested Michelin tires. US ordered cars cannot spec the manufacturer of the tires. In ROW (rest of world) when ordering you can spec. the tires.
When my car arrived it had Continental Pro Contacts on it. I drove directly from the dealer to Direct Tire and had them put on Michelin Pilot All Season Plus tires. Came with 45,000 mile warranty, free balance, rotation. I now have 21,000 miles on them and they are still fantastic. I expect to get over 50,000 miles before i will need to replace them. It is sad Mercedes puts such poor quality tires on such a great car. Cheers
__________________
11' E350 Sport Wagon, Arctic White P2, Natural Beige Leather, AMG Wheels 2014 C350 Sedan on order. |
#8 | |
Quote:
Continental tires frequently get very high marks in tests like here and here. |
#9 | |||||
Quote:
Quote:
Also, at least for my e350, the recommended psi under NORMAL is 30psi front...and 35psi rear. Its printed on the backside of the fuel lid. Maybe 30psi is too low for the front? Thanks for the tip...I'll look into that. Quote:
Quote:
Quote:
Seems odd...maybe I got a bad batch? I only got 11K on the odometer.
__________________
![]() 2011 GLK350 - P1, Multimedia & AMG Pkg 2010 E350 - P2 w/ 18" AMG wheels 2001 GS300 VIP Style |
#10 | |
Quote:
This really looks like an underinflation/alignment issue that caused these issues. Just go to a tire dealer dealer and have them evaluate it. |
#11 |
PHML.. Im pretty sure my recommended psi is 36 front and 38 rear
#12 | |
Quote:
Can you take a pic of backside your fuel lid and post it up? Thanks.
__________________
#13 |
Drives: ///AMG
Do you do a lot of parking lot type turning? I mean like not or barely moving but turning the wheel a lot?
#14 | |
Quote:
Even so, why just the front tires are peeling rubber?
__________________
#15 |
Drives: 2004 SL55, 2010 E550 Sport, Recently departed C63, 2011 E350 (shouldda had a V8)
Front tires wear differently than rears, that's why tire rotations are recommended when possible. In this case it looks to me like excessive toe-in or really aggressive driving. Mercedes delivers C63's with so much rear toe-in that the rears are lucky to go 6K miles. I recommend that you have the alignment checked and documented with a printout. Compare it to the recommended spec's. with particular attention to toe-in. You may be able to dial back some toe without hurting straight line stability.
#16 |
Drives: 2008 Mercedes Benz S550, 2011 E350, 2013 SLK350
Quick question: I have a 2011 E350 sport with 4,600 miles. Can the dealer even do a tire rotation since my wheels are staggered?
__________________
Vehicles I Drive: 1) 2008 S550 - Capri Blue/Cashmere - Package 3, Premium Leather, Distronic PLUS, Rear Seat Package, AMG Sport Package, Wood/Leather Wheel, Rear Side Window Blinds, Panorama Roof, Active Body Control 2) 2011 E350 Sport - Black/Almond w/Burl Walnut Trim - Premium 1 and Panorama Roof 3) 2013 SLK350 - Black/Black - Black Ash Wood, Sport Package, Multimedia Package, Lighting Package, Pano Roof, Rear Spoiler, Chrome Hood Fins, Keyless-Go |
#17 |
#18 |
Drives: 2011 E550
That depends on how bad the camber is on these cars. If the wear is heavy on the inside tread then it's worth the $100 bucks to rotate compared to the cost of replacing the tires IMO.
__________________
2011 E550 |
#19 |
If they are asymetric tires then the inside will stay the inside. The other risk you run is damaging the wheel when removing/reinstalling the tire.
#20 |
Drives: 2012 C300 4Matic
ContiProContact tires are some of the worst you can possibly put on a car. There was a thread similar to this one on the C class forum where someone posted a link to reviews - many people have been injured in accidents thanks to these wonderful tires. They are known to bubble and blow out due to pot holes quite often. We had this happen to all 4 of them on our E. All 4. Never had a bubble on any tire on any other car where we live.
#21 |
I really liked my cont's, they came on my 550 at delivery......wish I still had those things
__________________
#22 | |
Quote:
The Ford explorer came predominantly with Firestone tires. Because most owners had Firestone tires, they were blamed even though subsequent tests showed that the tire brand was irrelevant. The BMW 5 series with the sport package comes with Goodyear LS tires. Those owners will tell you that the Goodyears are the worst tires ever because they bubble. The 2008 R32 was fitted primarily with Dunlop tires. Because of bubbling issues, those owners will tell you that Dunlop tires are the worst tires ever. My 2003 Audi RS6 came with Michelin and Dunlop tires. Because they bubbled, those owners will tell you that Michelin and Dunlop tires are the worst ever. In all these cases, the problem is the low profile tires and crappy roads in the US. Other tires will have the same problem but since one tire brand usually prevalent, that brand takes all the blame. |
#23 | |
Drives: 2011 E550
Quote:
They are not asymmetrical they are directional. Yes we know about possible rim damage. You sound like you have incompetent tire stores or dealers where you are. I have been rotating tires like this for years with no issues or damage to my rims.
__________________
2011 E550 |
#24 | |
Drives: W212 E550, 2011 ML350
Quote:
I would increase pressure to 34 and see if this is resolved. I use 34 on my fronts and they wear well (30K miles on Goodyear F1 summer tires). |
#25 | |
Quote:
None of these are critiques of the people asking the questions. None of us automatically know these things and it is the role of these forums to educate. Rim damage is rampant in all areas of the country. Many stores still use older equipment designed for higher profile tires that have metal bits intended to touch the wheel when breaking the bead. Accordingly, one has to choose a tire shop wisely or risk wheel damage. In addition, the low profile tire itself can be damaged during the unmount/mount process. All things to consider when determining if you want to dismount a tire to rotate it. I wdon't think that the costs and risks outweigh the marginal advantage. If I have uneven tire wear, I'd want to address it with an alignment rather than hiding the problem with a rotation. |
| Tags |
| 2012, 38, contact, contipro, contiprocontact, e350, mb, michelin, ml320, problems, psi, style, suck, threads, tires, vip, w212 |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Display Modes | Rate This Thread |
