Last edit by: IB Advertising
See related guides and technical advice from our community experts:
- Mercedes Benz E Class Exhaust System Reviews
Reviews and comparisons of top products
Introducing SuperSprint's W212 E350/550 Exhaust Systems
Former Vendor of MBWorld
CampioniShop is SuperSprint's newly appointed distributor in North America for Porsche, MB AMG, Audi S/RS applications. SuperSprint has developped a wide range of products for Mercedes-Benz including their new W212 E Class exhausts.
The system is available in 2 configurations: cat-back or axle-back.
You have the options to use the following parts:
TBA - we are awaiting confirmation on a few part numbers.
Sound clips:
Unfortunately the kit was designed on the Diesel version. This is a sport exhaust upgrade, the race X pipe will give it a lot more noise whereas the resonated X pipe will retain a civil tone.
About Supersprint:
Established in 1955, Supersprint® developes and handcrafts the best sport car performance exhausts in the business. The engineers at Supersprint realize that for maximum performance, exhaust development must begin at the exhaust ports of the cylinder head. This is why Supersprint has the largest variety of racing header systems in the world today. Each header incorporates CNC laser cut port matched flanges. Primary tubes are mandrel bent using the latest CNC tube bending equipment. With special tooling Supersprint has been able to keep weld joints to a minimum for added reliability.
The fully appointed R&D department uses the latest in prototyping equipment along with the reliability and accuracy of a MAHA "all wheel drive" chassis dyno. With over 50 years in performance exhaust development they have earned the confidence of many of Europe's most respected tuners. Most units are 100% stainless steel.
- Mandrel bent
- Full systems available
- Dyno tested
- CNC machined
- 304 stainless steel
- Hand welded joints
- Unlimited mileage warranty
- Made in italy
- Center resonated X pipe
- Center racing X pipe
- Connecting pipe for axle-back
- Rear mufflers
- 4x80mm tips
- 4x90x70mm tips
- 4x120x80mm tips * for AMG bumper only
- Connecting pipe for OE tips
Sound clips:
Received 3,351 Likes
2012 CLS63
good luck selling these here.....
2012 S350 Bluetec 4Matic, Diamond White, P2
CampioniShop, You mention it was developed on a diesel model. Will it work with the US spec E350 Bluetec? Also, I would want to hear some sound clips to audibly demonstrate the difference between your "mild" and "wild" setups (on a Bluetec preferably.) Is the CDI the same as the Bluetec W212?
Yes sir, it was developed on the E350 gasoline and E350 CDI model. The rear section (mufflers and tips) will work on the diesel model - the diesels however have a Y pipe for the mid pipe instead of a true dual. It's a tad cheaper than the gasoline system.
Anyone buy one of these? How much do they go for? I also want to bring out my V8 sound and looking into what other options are there. Meisterchaft is also a good alternative and they go for around $1800 shipped. We need a group buy here to get a better deal
