Go Back   MBWorld.org Forums > Mercedes-Benz Sedans > E-Class (W212)
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Members Insurance Search Today's Posts Mark Forums Read CarsGarageVendors
Welcome to MBWorld.org Forums
E-Class (W212) 2010-present: E 350, E 550
LinkBack Thread Tools Search this Thread Rate Thread Display Modes
Old 04-14-2012, 03:44 PM   #1
cmb13's Avatar
e350 Shift Pattern Driving Me Crazy!
Folks,
We have an e350 4matic wagon, purchased new about a year or two ago (right when the new wagon came out). The car is just terrific in all ways, except one.
It seems you have to floor it to get it to downshift. It is quite annoying, dangerous even, when merging onto a busy road or highway. I have to keep pushing the pedal harder and harder, and it just seems to stay in a high gear unless I floor it.
I have had many cars, some sports cars, some luxury sedans, and I don't ever remember one feeling this unresponsive. Is there a way to change this? Reprogram? I'm not trying to drive aggressively, I just expect that if I'm, say, 50% on throttle, it would kick down a gear or two.
Thoughts?
To remove this ad, register today or login if you already are registered!
cmb13 is offline   Reply With Quote
Old 04-14-2012, 05:53 PM   #2
thekurgan's Avatar
Drives: E350 BT
Do you have the Economy/Sport button? I found the sport button dropped into the lower gears faster, and also held the rpm higher for a longer period of time.
__________________
2011 E350 BlueTEC: Steel Grey / Ash Sport, P1, Deck Spoiler, 115V Outlet
thekurgan is offline   Reply With Quote
Old 04-14-2012, 08:56 PM   #3
Drives: 2010 E550 4matic
Here is the issue as I understand it: The transmission learns from your way of driving, and responds accordingly. So if nearly all of your driving is sedate, the transmission is sedate. In a sense, the transmission doesn't know that 50% throttle means you want to "get up and go."
Hitting the E/S (or maybe C/S) helps, but is not entirely satisfactory to me.
In my car, I can do a very quick double pump to about 50% power, and it will go down a gear. I can maintain speed, and the tranny will hold the lower gear for maybe 3 seconds or so. If it then goes to a higher gear, then for a while (don't know how long) all it takes is another single 50% pump to get it back into the lower gear. Or if it has not gone back to the higher gear, another single pump will put it another gear down and the car gets really "jumpy" (very responsive to the throttle).
What I don't know is whether every one's transmission behaves this way, or if somehow I have "taught" the tranny that a double pump means I am not screwing around. In my personal experience, talking to the tranny with my foot is a lot more convenient and even faster than hunting for the E/S button as well as more effective.
Another trick if you have paddles is to hold the left paddle for about a second. The car will go into the lowest gear possible given the speed of the car. When you have completed the pass, then hold the right for about a second to go back to the normal gear. The car will shift near redline, so there is no need to worry about running out of gear in the middle of your pass.
I love this tranny except for one feature: It will sometimes downshift in the middle of a turn, which is the 550 is not desirable!
ttoE550 is offline   Reply With Quote
Old 04-14-2012, 09:46 PM   #4
K-A
K-A's Avatar
Drives: '13 BMW 535i M Sport / Ex M-B's: '11 & '10 & '06 E350's, '02 S500
For whatever reason, my current E's tranny and motor are very snappy and immediate. Can't complain about that. Much more-so than my previous E's I feel.
BTW, I'm not sure but I think M-B states to "not change from E to S or vice versa while driving in motion", i.e you're "supposed" to do it while stopped.
__________________
'13 F10 BMW 535i ///M Sport : Jet Black/Black-Anthracite : Premium & Technology Packages/Sport Auto Trans/Camera/Park Distance Control/Heated Seats/Tinted Windows/Blacked Out Markers/Performance Spoiler.
Ex M-B's: '11/'10/'06 E350's w/ AMG Sport Package, '02 S500 w/ Every Option.
K-A is offline   Reply With Quote
Old 04-14-2012, 10:11 PM   #5
Quote:
The manual is loaded with ridiculous cautions that must've been written by lawyers. Some are so funny that my wife and I busted up when I read them to her.
If they meant it, they would block it. I've raised my car (Airmatic) at speed and switched from E to S at speed, and so far I have not experienced serious injury or even death!
Now if I were driving 150 mph on the autobahn or something, I think I would be more reluctant, but that's common sense.
Just joshing...
Old 04-14-2012, 10:17 PM   #6
thekurgan's Avatar
Drives: E350 BT
Just joshing...
+1, not being able to use it while driving is ridiculous. If anything, if there is a throttle remap, you'd have to let up on the throttle completely for it to remap, but agree, I just hit the button when I need it and it's responsive.
__________________
Old 04-15-2012, 02:41 AM   #7
Drives: w212 E550
the "s" mode definitely helps but one of the members here had the dealer update the sw and it cured the problem.
BM2BZ is offline   Reply With Quote
Old 04-15-2012, 11:30 AM   #8
Drives: 1991 300d 2.5 turbo
i'm pretty sure you can "teach" these tranny's your driving style. there's a computer mounted right on the trans after all. sport mode helps, but can't you just manually downshift if you wanted to?
burrito_bandito is offline   Reply With Quote
Old 04-15-2012, 05:07 PM   #9
Arrie's Avatar
Drives: 2010 E550
Just joshing...
Your car will not raise and it will automatically lower at high speed somewhere around 70 mph (110 km/h?).
Arrie is offline   Reply With Quote
Old 04-15-2012, 05:30 PM   #10
Arrie's Avatar
Drives: 2010 E550
Quote:
Originally Posted by cmb13 View Post
Folks,
Thoughts?
As others have mentioned S-mode helps but there is another way to help the situation. At least this worked on my 2011 E350 and it works on my current 2010 E550. Did this last night to verify and it does work.
This is about resetting the control module for the transmission. I understand it is a learning kind of a module that sets parameters based on your driving habits. It tunes the transmission for shift points etc, which seems it always tunes it down to less aggressive driving.
There is a lot of writing about this in the forum and that is where I originally found this.
One suggestion is to disconnect battery cable over night to reset the module. I personally would not do this.
Another is to find an open road or a very large parking lot without traffic and do a fast acceleration to 30 mph and let car coast down to 7 mph WITHOUT TOUCHING THE BRAKES and repeat it three times. Sounds complicated to me as it takes a very big parking lot or quite long road without other cars to perform.
But then there is this:
1. Get in the car and close all doors.
2. If you have Keyless GO remove the Start/Stop button from the dash.
3. Insert key and turn in position 2, i.e. ON position but do NOT start the engine.
4. Floor the gas pedal and hold at least 5 seconds. I held 10 s.
5. While holding the gas pedal down turn key to OFF. Do NOT remove the key.
6. Release the gas pedal and wait 2 minutes. Do NOT open doors or remove the key. Just sit and wait 2 minutes. TIME IT! (I waited 2 1/2 min).
7. Take key out, open door exit car and you are done.
8. Go test drive and enjoy!
Above works for me.
Old 04-15-2012, 05:43 PM   #11
Quote:
Well that's a possibility. I will have to try it. It makes sense from an aerodynamic perspective. Thanks!
Old 04-15-2012, 08:32 PM   #12
cmb13's Avatar
Wow, this is a great forum! Thanks for all of the responses.
With regards to the S setting, I hardly ever remember to press it. I am trying to do it every time I get in now. It still seems very sedate, seems as if it hardly does anything at all. I really wish it would default to the last setting, though, rather than back to C.
I have occasionally used the steering wheel shifters, but the problem is I really drive pretty conservatively, at least in this car. It is only on the occasion that I have to merge into traffic or want to beat a long yellow or something that I step on it some more, and seem to get absolutely no response.
The reprogramming of the software seems like a great option if they would do it.
Finally, I'll try the above tricks, maybe starting with the double pump of the pedal, then the 0-30 repeats, and lastly the above method of inserting the key to "2" and doing the above technique. I cannot imagine why this would work unless the tech guys at MB anticipated some would want to change the setting and provided a cheat intentionally.
Thanks for the responses!
Old 04-15-2012, 09:24 PM   #13
Drives: w212 E550
Above works for me.
seriously ? most of us owe you big time if this works . by looking at your method, i assume i don't even need to worry about locking the door first or turn off both the a/c and music, right? i know the car won't move but floor the gas part freaks me out a bit .
Old 04-16-2012, 12:25 AM   #14
Arrie's Avatar
Drives: 2010 E550
Quote:
And why does the flooring the gas pedal freak you out? By the instructions the engine is NOT running while you do this.
When I do this I touch nothing else. I have my climate on AUTO and radio comes on to what ever it was left on. They run until I turn that key OFF and open the door.
And you do not owe me. You owe some other folks who posted this. I just dug it up again...
Old 04-16-2012, 01:05 AM   #15
Drives: E550 4Matic
I do the same with my car with the double pump but I have a feeling the responsiveness you are talking about has more to do with your V8. Even in C mode with my usual sedate driving I can easily get quite a bit of acceleration without really stressing the transmission so much by simply engaging the throttle faster. I think with a 350 the effects of the car learning typical sedate driving to be a lot more pronounced...
As a rule if I need the best acceleration I always switch from C to S so to the OP I would recommend that you do your normal driving in C and then switch to S whenever you expect to do more spirited driving and the car will learn your throttle behavior in S mode.
WEBSRFR is offline   Reply With Quote
Old 04-16-2012, 01:12 AM   #16
Drives: E550 4Matic
I think the point is to not do all your driving in S mode if you drive most of the time like a normal and sane driver. In which case in the S mode the car is going to think you are a hundred year old grandpa and you are going to have the same problem. Drive with C and punch S when you need to. That's what I do and I get great throttle response. You might have to learn this but I think you will be better off. Out of habit, my right had is always close to the gear shifter so hitting S is almost second nature for me now.
I especially like the gentle nudge I feel when I am stopped at a traffic light and I hit S and the transmission downshifts from 2 to 1. It's like the car telling me: Do what you need to do, I'm with you all the way
Old 04-16-2012, 04:22 AM   #17
BenzV12's Avatar
Drives: 2012 W212 E250,2014 C117 CLA45 on horizon
Send a message via AIM to BenzV12 Send a message via Skype™ to BenzV12
I appreciate your humble message , kudos to you
__________________
Colleen Riley is the best female vocalist
1 thing 2 say 3 Days Grace 4 ever
Eicoot Quit The Job (Finally)
Alex De Souza Is A Legend
BenzV12 is offline   Reply With Quote
Old 04-16-2012, 05:35 AM   #18
Drives: w212 E550
i know the engine is not running but just like walking on glass floor on top of some tall buildings, you know you won't fall but still freaks out a lot of people .
thanks for your time to dug it up for us again .
Old 04-16-2012, 09:11 AM   #19
Kar don's Avatar
Drives: Mercedes-Benz
To the OP: sounds like you are slowly digging into the pedal and getting no response. The computer reads pedal inputs and the rate of speed at which the pedal is depressed. This means if you ease into the pedal you are not likely to get a downshift; however, if you stab the pedal (pushing it down quickly) you will definitely get a downshift and more immediate power.
Kar don is offline   Reply With Quote
Old 04-16-2012, 09:16 AM   #20
Ah, the long yellow! That's when you don't have time to screw around. But that's a case where I'd give it 100% throttle at least for a moment because I really do want to speed up (and not just get ready to speed up). In my experience, the car responds instantly.
I don't understand why it freaks people out to give a car 100% throttle. One of my cars (I forget which) had a physical button on the floor under the throttle. To induce a downshift, you had to floor the throttle to press the button. Click, Zoom! I think the engineers make this the universal sign for "Get moving!"
Yes, my 550 might be more responsive, but I can see the RPMs jump when I do the double-pump even though my speed does not change much. So it is a gear change too.
And as WEBSRFR recommends, do NOT put the car in S mode for every day driving. The car will learn that you don't really mean it, and it will not be different from E (or C) mode. You probably notice this after a couple minutes of driving - and over time, you will lose those couple of minutes.
Old 04-16-2012, 01:07 PM   #21
cmb13's Avatar
Interesting points. I guess I'm used to a stick (most of my cars have been stick), in which case I'm in the gear I want and can give any amount of throttle I need for more acceleration. My last car, for instance, the C6 Vette in the avatar, was so powerful if I floored it in that situation the rear end would break loose (even with traction control). I'm used to just nudging a little more out of the gas and getting a response. My current car (335i) is an automatic also, and it responds a lot more quickly than the MB (my wife's).
Funny the MB is quite capable, it's just that hanging on to a high gear unless floored that annoys me. Bottom line is that I really just like a stick!
Old 04-16-2012, 01:53 PM   #22
I love driving manual transmissions too. I don't know why, but I just remember a typo Dave Barry found in some car magazine "There is nothing better than a well-timed shift." In the typo version, the f was missing.
Unfortunately, auto transmissions get more and more complicated with all the environmental regs and stuff. I suspect as well that not only does the car quickly go into the higher gears but also the accelerator goes into less aggressive mappings. These things probably increase mileage figures in testing but hamper normal drivers.
I drove a Viper once around a race track with no TC. I would not suddenly floor that car! In fact, it was pretty hard to keep the back end in the back just with bare touches of the throttle.
Tags
2010, 2012, change, e350, economy, gears, im, long, low, mb, mode, park, problem, reverse, shift, software, taking, transmission
Search this Thread:
Advanced Search
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Copyright © 2001-2012 InternetBrands, Inc. / MBWorld.org. All Rights Reserved.
Everyone's Personal Details
SEO by vBSEO 3.5.2
