Sign in using an external account
| E-Class (W212) 2010-present: E 350, E 550 |
LinkBack | Thread Tools | Search this Thread | Rate Thread | Display Modes |
#1 | ||
Drives: 2011 E350 Bluetec, 2007 GL450, 2003 E500 (GONE)
Fuel tank capacity (bluetec) mystery
#2 |
Drives: 2012 E350 Bluetec • 2011 Audi A4 2.0T
You're math is off. 80 liters is 21.39 gallons (3.74l per gal.)
#3 |
__________________
http://www.youtube.com/watch?feature...&v=0kQ73UgGIRU new COB coming soon!!!!!!!!!
#4 |
Although the official literature I've seen has been a bit confusing...it makes reference to a "reserve" amount...I've alway assumed it was just over 21 US gallons.I've had my BT down to almost zero a couple of times (or so I've assumed) and the most it's ever taken has been 19.8 US gallons.
#5 | |
Drives: E550 4matic Tenorite (Steel) Grey
Quote:
which is 21.4 US gal or 18 Imperial gal. or 0.335 hogsheads (US) or 0.2444 hogshead (Imp)... you get the picture
#6 |
Drives: 2012 S350 Bluetec 4Matic, Diamond White, P2
Speaking of which have you checked the price for a hogshead of Premium these days?
__________________
___________________________________ 2012 S350 Bluetec 4Matic, Diamond White, P2, Flux Capacitor, Mr. Fusion, and one jar Gray Poupon. |
#7 |
#8 | |
Drives: E550
Quote:
Eh?
__________________
![]() 2011 E550 Luxury, P2, Driver Assist (DISTRONIC Plus, Pre Safe Brake, Blind Spot, Lane Keeping), Massage/dynamic seat, Parktronic, Folding Rear Seats, Wood/Leather Wheel, Diamond White |
#9 | |
Quote:
![]() I don't know if any of the rest of you have that kind of pricing, but one of the newer ways the oil companies have to [s] gouge [/s] enhance profitability is to adjust the apparent volume of gas pumped as if it were at 15 deg C (which of course is 59 F) |
#10 |
Guys,
Sorry for the confusion I might have caused. I pulled up a British User Manual on line and sure enough it said 18 gallons on the Specifications sheet. But this is due to difference between the US and British gallons. It now makes perfect sense !Now, I think that my Low Fuel indicator (the yellow one) goes off way too early. I once filled up the tank right after the yellow light came on and it only took 18 US gallons to fill it up. So, this makes the reserve of 3+ US gallons. That would give me close to 75 miles of driving in the city (I have Bluetec). |
#11 |
Only 75 miles on 3 gallons? Something else must be off too.
__________________
#12 |
Sounds about right to me.
My low fuel light also comes on when I have approx. 3 gallons left I would estimate because the estimated range shows around 30 miles left usually, and I keep driving, and then the second warning comes up on the center display (the one where it no longer shows you the range, but a picture of the car with a fuel pump next to it) and that is usually when I fill up and it takes right around 19 gallons. |
#13 | |
Quote:
I like liters , dislike galons always leads to confusion
__________________
![]() ![]() Colleen Riley is the best female vocalist 1 thing 2 say 3 Days Grace 4 ever Eicoot Quit The Job Alex De Souza Is A Legend |
#14 |
#15 |
Drives: Late Built 2005 W-211 E-320 CDI
![]() One US gallon is exactly 3.7854 liters, so wouldn't 80 liters be 21.1338 gallons? ![]() ![]() Derrel
__________________
See Fuelly: http://www.fuelly.com/driver/derrelhgreen/E320 ![]() Dynoed 210 HP, 386 MAX TORGUE at the wheels. Surprised me to say the least. |
#16 | |
Drives: E550
Quote:
When you think about it, since fuel is almost invariably stored in ground, 59 degrees is not far off what you would expect on ~almost~ any normal day. There has to be a standard, and 59 degrees is a pretty good one. Long range pilots of the long past used to fill their tanks in cold storage buildings at airports. They'd then hurry like hell to taxi and take off before the warming fuel blew the tops off the tanks!
__________________
#17 |
![]() What I would like to see is for all of us to post actual tank averages and not what the computer says! I always do better by the computer, but when I fill mine and do the math the old fashioned way, mpgs are always less. ![]() ![]() Derrel
__________________
#18 |
Drives: E550
You are so right. On a recent 3,000 mile trip, my 2011 E550 road mileage was 28.9 measured at the pump. The computer said I got 29.9. The difference has always been about that amount. (70% interstate, mountain west and desert driving.)
__________________
#19 | |
Quote:
![]() Your extremely high fuel economy leads me to think that maybe you forgot some of the gas you added during your long 3,000 mile trip. ![]() Do you know how much higher than the EPA estimates that is? The EPA lists yours at but 23 mpg on the highway. When I figure tank mileages, the figures are always less than what the computer will say! Start a Fuelly and record each and every tank and let us see how you do please. Yours is the older 5.5 L motor. The 2012s have smaller engines at 4.7L and are listed as doing better than yours, even though they are 4-matic. ![]() Derrel
__________________
See Fuelly: http://www.fuelly.com/driver/derrelhgreen/E320 ![]() Dynoed 210 HP, 386 MAX TORGUE at the wheels. Surprised me to say the least. Last edited by Green E-300 DT; 07-15-2012 at 11:10 AM. |
#20 | |
Drives: E550
Quote:
Each and every tank and mileage was recorded. I'm not about to send you the spread sheet. And I'm not about to do your "fuelly" and send you results. My trip was a "fuelly," as you call it, and you have the results. I did the identical trip, even to hotels occupied, a year earlier. The average for that 3,000 mile trip was 27.1 (vs. 28.9 this year). I attribute the difference to high winds on the earlier trip and possibly to a car barely broken in. FYI, the EPA numbers are "estimates" and based on dynamometer tests, at EPA specified speeds, and assumed calculations to simulate real-world conditions. You will see many comments here on road trips far exceeding EPA highway mileage ratings.
__________________
#21 |
The EPA rates mine at 33mpg highway.On a couple of occasions I've gotten 38mpg on *long* stretches of Interstate under less than perfect conditions...conditions like A/C on full blast (105 degrees) or when using winter diesel (which gives lower mileage).And yes,I used the fillup-to-fillup method to calculate and didn't forget to log any fuel bought.
#22 | |
Quote:
![]() Yours I do believe! Not the 38 mpg for true tank averages however. Computer yes, but tank mileage, no. I have seen mine report as high as 45 mpg running on a long trip from Sacramento to LA, but it did not do nearly that amount when figured out fuel used for those miles traveled. Why is the 33 mpg correct? Because it is 'right on' with what many others on Fuelly record. When someone tries to say that they drove 3K miles with a big V8 gasser (5.5L) and got tank mileages of 28 plus mpg, well that is simply too much and not believeable and I do not except that! ![]() If that were true, no one would be buying diesels. Ask why MBZ dropped down with the E-550 (5.5L) to a smaller 4.7L for the currect model. ![]() They were after better fuel economy, and IF the older 5.5L was doing as well as some here claim, why would they have gone smaller? ![]() Post your true fuel economy on Fuelly. That is how to report true fuel economy! ![]() Derrel
__________________
See Fuelly: http://www.fuelly.com/driver/derrelhgreen/E320 ![]() Dynoed 210 HP, 386 MAX TORGUE at the wheels. Surprised me to say the least. Last edited by Green E-300 DT; 07-16-2012 at 11:20 AM. |
#23 |
The lowest I have seen in my BLetec is 28 mpg. Te Hihest is 44 mpg. Now I have close to 40k on mine, so it is almost broken in.
__________________
#24 | |
Quote:
Feel free to believe that I'm either lying or that I flunked 3rd Grade arithmetic if you wish. |
#25 | |
Drives: E350 BT
Quote:
| Tags |
| 1990, 2003, a4, audi, capacitie, capacity, e350, e550, fuel, gas, left, low, mb, on, symbol, tank |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Display Modes | Rate This Thread |
