E350 2010 bumper type and LED drl cover grille question
Old 12-21-2013, 04:05 PM
  #126
jerome8283's Avatar
GLS450
Originally Posted by Hfdafhx
HOW DO THEY FUNCTION/WORK, DO YOU TURN ON YOUR FOGS? OR AS DRL? OR OTHER
The LEDs act as DRL.
Old 12-21-2013, 04:06 PM
  #127
jerome8283's Avatar
GLS450
Originally Posted by WebOs
Dealers won't touch any of that. They said it will cost 3-4k for them to work like the new
Local shop not Mercedes dealer, sorry.
Old 12-21-2013, 04:22 PM
  #128
WebOs's Avatar
E350
Do you get a message on your dash stating check DRL left and right when u start the car?
Old 12-21-2013, 06:13 PM
  #129
jerome8283's Avatar
GLS450
Nope, no message on the dash.
Old 08-09-2014, 10:53 AM
  #130
tate16t's Avatar
S550
Was anyone else able to swap the round fogs for straight LEDs and get the LEDs to come on at night as well as during the day?
Old 08-09-2014, 12:12 PM
  #131
WebOs's Avatar
E350
U have 2 choices...
1. Connect the led to DRL
2. Connect the led to the fog.
Each r separate sockets.
LED can connect to only one of the lights.
I've connected it as fog it works n drl. As fog light u can turn on manually in day time but night u won't be able to turn it off if it comes on automatically. They r very bright. I just have them connected to DRL n they go off when the head lights come on.
Old 08-09-2014, 12:42 PM
  #132
WebOs's Avatar
E350
It's very easy to do if u need help let me know.
Old 08-09-2014, 05:15 PM
  #133
tate16t's Avatar
S550
I already had the round fogs swapped out for straight LEDs. A local shop did mine and at the time I was told they could not wire them so that they would come on at night. Right now they serve as DRL and come one when the car is turned on, only during the day. I wanted to see if anyone got them working at night as well.
So, you could not get them to come on at a lower brightness like the stock ones?
Old 08-09-2014, 06:24 PM
  #134
WebOs's Avatar
E350
You would need to change the power supply and tweak the computer in order to work like the stock. 3-4k ain't worth it. At least that's what the dealer quoted me.
Old 08-09-2014, 07:12 PM
  #135
tate16t's Avatar
S550
My dealer once told me installing the straight DRL's was not possible.
Old 08-18-2014, 01:10 PM
  #136
Optima2003's Avatar
White E350 W212 with Panorama Roof
I have a 2011 W212 with LED hockey stick style DRL at lower....if I want to upgrade it to the 2012/2013 straight line LED style...will that be a direct swap by using the following parts without adding switches, cutting wires or something crazy...?
2128851753
2128851853
2128852174
2128852274
Plus the LED lights kits
Just want to see this is something I can do it myself without spending more then $500...and I can still sell the hockey stick kits for $100 or so...thanks in advance.
Old 11-12-2014, 11:30 PM
  #137
OceanView's Avatar
W212 & W210
Any updates on this?
Wish someone did a DIY with photos.
Old 01-20-2019, 09:06 PM
  #138
S550e's Avatar
W222 S550e, C207 E550, W212 E350
Sending this gem back up to the top. This is the write up I will be using for my conversion. Sadly, many of these members, including the OP, no longer use MB World. Ales Lukaz email still works and I have already been in contact with him. He said he will check back with me if he can still do the custom wiring for the DRL. I spent hours looking for a thread like this. Exactly what I needed!!
Old 02-23-2019, 02:48 PM
  #139
MA6226's Avatar
2010 E350 4matic
did you have to change any wiring ? So basically you got the new LEDs and Grilles and swamped them out ?
Old 09-01-2021, 09:06 AM
  #140
Ernest 2075's Avatar
E350
Relays
Originally Posted by kalt
If you prefer not to solder or tap into the original harness you can use the cables below. You can also use a spdt relay on each side of the car to flip between the fog and drl cable. This way the LEDs come on durring the day, when you unlock the car or manually turn on the fogs. This method will also prevent bulb out warnings.
DRL CABLE
http://www.ebay.com/itm/130915483298...84.m1423.l2649
FOG CABLE
Amazon.com: Halo Automotive WHH11 Plug and Play Upgrade Wire Harness for H11 Bulb - Twin Pack: Automotive
How do you connect those relays the way can work like that ??
Quick Reply: E350 2010 bumper type and LED drl cover grille question
