20 inch wheel fitment...vossen
Hey guys
my buddy has a w212 and he wants to put a set of vossen cv1 on it in 20s. the problem is, apparently vossen only makes 20x9 +32 and 20x10.5 +42...will these fit? the car is a e350 rwd.
from what I read you guys are running +35 offset all round to be flush? will +32 up front work with a slightly stretched tires?
thank you for your help! and sorry for my noob-ness on e class lol
I'm not positive about the rear, but the front will be close. I am running a 8.5" up front with -35 offset and I'm pretty flush, so a wider wheel and -32 will stick out I believe. My rears are 9.5" wide and also -35 and it can't get any tighter, flush as flush can be..lol. I would do a search on this, there are so many topics and good answers about this all over. Sorry I couldn't be more of a help, good luck.
thank you for the help! will def search around...just doesnt seem like there is a definite answer to what fits and what doesnt.
also does anyone happen to know if sedans and wagons have the same wheel fitment?
14' CLS550
Just to give you an idea.. i had 8.5" upfront at 35et 235/35.. and 10" rear at 40 et 275/30.. that was very flush to fenders.. your setup will stick out more, will def have to stretch tires.. if you use my tire size you should work, but will be very stretched.
