Anyone else have a hard time reading the DIPSTICK?
Ok, I turned 50 this year - and am no spring chicken.
But damn - the whole plastic red oil level bit is wet with oil, even after many attempts to dry it & remeasure the oil - it just comes out wet past the cross-checked bit.
Is it just hard to read, or did the dealer "top it off" a bit too much?
Received 1,615 Likes
2014 E550-sold 😩
It's easy to read. Sounds over filled.
andrew L (09-04-2020)
UPDATE:
a) yes the dipsticks are hard to read.
b) I used an oil extraction pump, and pulled out about 42 oz. of OVERFILL by the dealership.
I now finally have oil readings just below the MAX limit on the dipstick.
Looking at my July 15th oil change invoice from the dealer - if I am reading it correctly - it shows 9 qts. of Mobil 1 5W-40.
The capacity on the 2012 E350 DI engine is 6.9 quarts.
I believe pre-DI 3.5L engines have a 8.0 quart capacity.
Sent a note to my SA and the dealership's Service Mgr. and waiting response. I've driven 1000 miles since the oil change.
2014 E550-sold 😩
That is not good. It is a good thing you were diligent and checked this. I am just happy to have a damn dip stick now. My last w211, as with everyone else, had no dipstick at all.
UPDATE II:
Talked to the Service Mgr. today. He indicated that if the pan was overfilled, that on the way home from the oil change, it would have tripped an error message on the dash. Ditto if the oil was a quart low.
He said the "dipsticks are not accurate", as oil pools into other places in the engine and won't be picked up via the dipstick. He advised me to put some/all of the oil I drained back into the engine.
At no time did my vehicle trip an error message.
So, in modern MB, the dipsticks are there to make us feel good and useful about DIY- but don't serve the "old school" purpose we all grew up with.
Whew....I thought it was just me having the problem. I checked my indy bill for the last oil change and they put in the correct amount....8 qts. And my indy uses the drain plug so I know it was emptied but I still can't read the level. Also, I think the "Add Oil" warning comes on when two quarts down....correct?
2014 E550-sold 😩
UPDATE II:
UPDATE II:
Sounds like they over filled the engine and that 9 at is what the E550 engine takes. Their mechanic probably just by accident used the wrong engine volume for the fill.
Dipstick absolutely is accurate and you should report this AS telling you it is not. Report should go to the dealership service manager AND the MBUSA.
And I don't think any harm was done to your engine for having the oil over filled.
2014 E550-sold 😩
If your dipstick is showing a correct reading as you say, I would not add any of the oil back, either. I just checked mine and it really isn't that hard to see if the oil is within the limits. I could see if it was over filled, and the stick was all oil, it would be impossible to read.
Yes mine is hard to read especially since the car is new and the oil almost clear.
I devised a workaround, take the dipstick and lay it flat on a paper towel and compare the mark to the stick.
E350 LUX 4M P2 D+
Drain Plug is located on the SIDE of the oil pan NOT the bottom. Kind of hard to know for sure it was actually emptied. BTW I DIY my oil changes with a MityVac and it is easy to measure the amount taken out and therefore the amount to put back (with a slight increase for the filter removal content). My E350 MY 2010 uses 7.5 quarts on each oil change (with new filter).
Your model (4M) takes 8.5 quarts when empty. Maybe your MityVac isn't getting all of it out A quart of oil shy out of 8.5 won't hurt anything but it certainly won't help....especially when it starts using/burning oil.
E350 LUX 4M P2 D+
It's still at the lowest point to drain. They have to design in a sump drain because some locations don't have access to a pump. Both methods are just as effective if done correctly but the pump can't be beat for convenience.
As I mentioned a slight increase in the amount removed by the MityVac (to compensate for the oil retained in the old filter; which is replaced with a new one at each oil change). My manual states my MY10 engine oil capacity is 8 quarts - which appears to me to be true after 5 years. BTW I am pleasantly surprised that this engine does not (has not) burn oil (premium gas is another story however).
Q, I am correct in thinking there is no digital readout we can get to?
